07-26-2019, 07:55 AM | #1 |
Drives: ZL1 1LE Join Date: Jul 2019
Oil pump failure - charge pump?
My zl1 1le is telling me to shut down engine due to low oil pressure.
It seems like my pump gave up. The issue is that I am located in europe way off from the dealer. So to the question, where is the pump located and can a none Chevrolet dealer Charge the pump? Last edited by gubel; 09-06-2019 at 05:00 PM. |
07-26-2019, 08:12 AM | #2 |
Drives: A10 LT4 Join Date: Aug 2016
You may very well likely need to replace...see the thread on oil pump failures. It should hold at 30 while at idle.
07-26-2019, 09:16 AM | #3 | |
Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
19 ZL1-1LE A10
07-26-2019, 03:54 PM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2018
The answer is that any mechanic can change it if they are even a decently good mechanic, but it is very labor intensive and will likely not be even remotely cheap.
07-26-2019, 05:21 PM | #5 |
Drives: 2016 2SS Convertible Join Date: May 2012
Contact Chevrolet to get your options. Your warranty should cover the repair and transportation to the nearest authorized repair facility.
07-26-2019, 10:00 PM | #6 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
07-27-2019, 03:51 AM | #7 |
Well noted, iam in sweden far away from any dealer.
I have a warrenty with the insurance company, the question is if any Other mechanic can charge the pump? Its a JULY 2017 production |
07-27-2019, 10:38 AM | #8 | |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Confirm warranty claim process with your warranty provider (the insurance company) and file a claim to make sure they'll cover the work. This repair should cost less than $1000 and take 1 day. And btw the correct word is "change" not "charge". "Charge" is what they'll do to your credit card to pay for the work :-) |
07-27-2019, 10:41 AM | #9 |
Drives: 2017 Colorado ZR2, 2018 ZL1 Join Date: Jun 2009
Can you describe the failure event? You said while on a track? Did you shut down immediately? How long after the light?
07-27-2019, 02:30 PM | #10 | |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
The chassis cradle and entire front of the engine must be removed to get to the pump.... definitely not a trivial job. |
07-27-2019, 05:03 PM | #11 |
Thats not good news, but in my experience full r and r of most engines is $1500-$2000. $2300 seems high for an oil pump swap even with removal of sub-frame and engine parts.
