03-03-2020, 11:23 AM | #3095 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Anyone got info on moving the pcm only? Looking to find out if I’ll need to lengthen or shorten any wires, and how many need to be adjusted. Looking to install a vacuum pump and I think the pcm will be in the way... not comfortable grinding down the cooling vanes as well.
Gracias
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-03-2020, 10:06 PM | #3096 | |
Drives: 2010 Camaro SS/RS CGM Join Date: Dec 2011
03-04-2020, 01:07 PM | #3097 | |
Thanks for the info!
2010 2SS/RS
03-24-2021, 09:20 AM | #3098 |
Drives: 2013 1LE Join Date: Feb 2012
Years ago I got flamed for saying this car was never going to happen. Was I wrong?
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013 |
05-07-2021, 08:29 PM | #3099 |
Got a new paint scheme and catch can for this year!
08-09-2023, 08:28 AM | #3100 | |
Will Cave
Drives: 2010 Victory Red 2SS LS3 Join Date: May 2023
Quick question. On the stock driver side valve cover there is a little port that sticks straight up. When I bought the car, this port was just open with nothing connected to it. I just put a vacuum line cap over it. I’ve seen pictures of some cars on here that have a hose connected to it. My questions are what is it for? And do I need to have a hose connecting it to something? Here’s a picture of what I’m referring to. |
08-09-2023, 10:31 AM | #3101 |
I believe that port was for the stock PCV system. Mine after the aftermarket LOD manifold I have is capped off. On the passenger side you should have one as well with a small diameter hose connected to it and goes to the intake tube. Pre TB and after the MAF. Mine does.
08-09-2023, 10:43 AM | #3102 | |
Will Cave
08-09-2023, 04:36 PM | #3103 |
Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
Yes it's a PCV system port, there is a hard-line that runs along the fuel rail and then loops right behind the throttle body into the intake manifold, here are some pics, recently had to switch it to a fuel line hose because it was in the way of fitting the ls7 fuel rail covers I'm working on.
Behind every scratch is a story on what not to do, and my car has a lot of stories.
01-25-2024, 05:45 PM | #3104 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
I have read this entire thread and I have been inspired.
Shout outs to blake-b and krusher especially. You guys paved the way! And of course the OP. What ever happened with him? I'm going all out. My biggest annoyance with my Camaro was the lack of paint under the hood. Imma gonna fix that.
01-25-2024, 05:52 PM | #3105 |
@blake-b
Do you still have part numbers for the pins in the fuse box and ECU? I'd rather install new pins on the shorted wires, instead of solder.
01-28-2024, 12:40 AM | #3106 |
Drives: 2013 Camaro 2SS "Diablo" Join Date: Jan 2016
I wish someone did this near southern Cali. I can’t imagine getting lost in a million wires.
Diablo - 2013 Camaro 2SS
Mod List: GM NPP Dual mode exhaust(Fuse pulled), AGP Twin Turbo 54/57, ZL1 Fuel pump with flex fuel sensor, ADM FPCM, ID1000 Injectors, diamond racing forged pistons, BTR twin turbo cam stage 2, Lunati forged H beam rods, BTR trunnions, ARP head studs, Vararam power wedge, MightyMouse Wild catch can, PFADT 1.25" drop springs, BMR Strut tower brace, 20x10.5 Giovanna Mecca rear and 20x9 Giovanna Mecca fronts, R1 Concepts drilled and slotted rotors, Hawk HPS pads, Night Owl RGB halo kit, and more... Future Mods: Dual fuel pump and more... |
01-29-2024, 09:24 AM | #3107 |
If you have time to take the car down for a while, and have the patience for tedious work. It's totally doable. Document everything, label everything, and focus on one task at a time.
01-30-2024, 09:46 AM | #3108 |
Rock on my friend! You have the patience of a saint!! Gonna be wicked nice when you get it all buttoned up. Good luck!!
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
New Texas Speed & Performance Engine Machining Center! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 01-16-2013 03:46 PM |
Hawk Performance Brake Pads part HB247Z.575 $85.00 | Rogan | USA - Florida | 2 | 10-07-2011 12:10 PM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
