12-01-2023, 04:07 AM | #1 |
Drives: Camaro SS 2013 Join Date: Jan 2018
Will these fit my 2013 SS convertible?
Chrome
20" 5 x 120 front 20x8.5 35mm rear 20x8.5 35mm https://www.nicheroadwheels.com/niche-1pc-milan if not, how do people make wheels fit that aren't "compatible"? |
12-04-2023, 03:24 PM | #2 |
Drives: 2012 Camaro 2SS Join Date: Jun 2023
Those should fit. The fronts will be tucked into the fender wells pretty good with a 35mm offset. Backs will be too at 8.5"w w/35mm offset. But they should fit.
Go to tiresize.com and you can play around with their offset calculator. If you know what's on the car now, you can plug in the existing info and new info to see how the changes effect various dimensions. |
12-04-2023, 03:40 PM | #3 |
