08-28-2022, 06:31 PM | #1 |
Drives: 2022 lt1 Join Date: Aug 2022
Am I good to go?
Hey all. Just recently did my first oil change on my new lt1. Did not realize the manual called for dexos 2 approved 5w30. I used Mobil 1 5w30 full synthetic dexos 1. Am I good to run this oil or should I go with the Mobil esp 5w30? Thanks for any input guys
08-28-2022, 07:34 PM | #2 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
The manual calls for 0-40 mobile 1 esp dexos 2 and that info is on your twist off oil cap on the engine also. If that is not available 5-30 dexos1 full synthetic is OK.
08-28-2022, 08:14 PM | #3 |
Thank you for clarifying much appreciated
08-28-2022, 08:34 PM | #4 |
You’ll be totally fine.
08-28-2022, 08:55 PM | #5 |
Drives: 2022 Vivid Orange LT1 M6 Join Date: Apr 2018
Fine as long as you don't track or race the car.
08-29-2022, 05:20 AM | #6 |
That’s silly. When the 6th Gen was released 5w-30 was the factory fill oil and you could definitely track the car.
08-29-2022, 07:42 AM | #7 |
If you are going to use the car in colder temps I see you are in the northeast like me, 0-40 allows for quicker lubrication for the cold startups. Its a known fact that cold start ups and thicker oil = wear. Remember 0 weight flowability on start up any time is good and better when its 20, 30, 40 degrees.
08-29-2022, 07:49 AM | #8 |
Mobil 1 esp dexos 0-40 spec oil was specifically designed for the LT4 corvettes and the LT1 grand sport /Z51 corvettes for track use so they didnt have to change the oil to track them. I believe that carried over the the 1LE Camaros also, that is why it has been a factory fill now for at least 4 years on all the LT1s and LT4s in camaro and Corvette
08-29-2022, 08:03 AM | #9 | |
Hot Camaro
GM upped the recommendations to the dexos2 oil a couple of years in, presumably to reduce their exposure from issues at the track. |
08-29-2022, 08:10 AM | #10 | |
08-29-2022, 08:54 AM | #11 |
Ya I think I’ll just go 0w40 I do plan on driving this car in cold temps as I just put on some summer ps4s and kept my all seasons. Thanks for all the input guys also if anyone has good place to get the oil shoot me a link please rockauto is all out
08-29-2022, 12:00 PM | #12 |
Drives: chevrolet camaro Join Date: Feb 2021
oil change
i always use mobil 1 5w 30 for years...no problems
