12-11-2016, 09:41 AM | #29 |
Drives: C7 Z06 manual, 18 Zl1 manual, etc Join Date: Dec 2013
A few pics for you guys to see. I can't say but to me it has to somewhat restrict airflow, power, and /or sound. Mine obviously came off and I went 3" no cats full headers back.
12-11-2016, 02:17 PM | #30 | |
It's tough to say because I replaced the crushed sections after I installed an aftermarket axle back and I haven' seen anyone that did mid pipes and left the stock exhaust but I can say that with my set up I had the Borla S-Type Axleback w/ NPP (11924) and after I installed their mid-pipe and x-pipe (60610) (which did replace the crushed sections) and is only a 2.75" OD there was a difference in sound. It was a little deeper and a little louder, not crazy loud but just enough to notice a difference and for me just enough because I didn't want it ear ripping loud.
12-11-2016, 02:35 PM | #31 |
Just finished installing my Borla mid-pipes and x-pipe so I figured I'd take a few close up pics of all the crushed sections of the stock exhaust. The big one is the one everyone always talks about after the x-pipe near the rear axle, and the other are actually up near the secondary cats right where they bend up. Hope this helps for anyone considering upgrading their exhaust but isn't lucky enough to have access to a lift.
12-11-2016, 02:37 PM | #32 |
12-11-2016, 03:56 PM | #33 | |
Drives: 2016 2ss Join Date: Oct 2016
These mid pipes and kits are being made to take advantage of people who don't know anything about their car. Unless it deletes the secondary cats, or your midnpipes are rusting, there's no need for this stuff. |
12-11-2016, 04:13 PM | #34 |
Drives: SS 6 speed of course Join Date: Jan 2016
It is NOT the same "flow" the flow area is much smaller. It is a restriction is another story. The poster clearly said he was doing if for sound. It does not matter if it is this pipe or the entire exhaust after the primary cat there is little to be gained. The general real world thinking is 10 HP when combined with LT headers and off road pipe. The factory header is 2.1" ID and the front cat is heck of small and bent. So gut feeling a after primary cat back is worth say 0 to 5 HP, 2.5 is the bell. So the guy wants to spend $75 bucks at the local shop for grins. How about the guy that spends $1500 for a fancy primary cat back exhaust and gains 2.5 HP? Heck LT and off road pipes is worth 12 to 20 HP say the bell is at 16 for $1000. Anyway you look at it this expensive bang for the $, heck removing the crush bend might just be the BEST bang for dollar, just that the gain is within measuring error.... so relax.
I think it sucks and will slide hammer and braze mine when I get unlazy (could be years).
12-11-2016, 04:18 PM | #35 |
Drives: 17 SS a8 Join Date: Feb 2010
Someone above said about 5/8 of the area. That looks pretty close to me. There is a much smaller cross section.
12-11-2016, 04:48 PM | #36 |
rough calculations
stock header 2.1 Id, about 2.25 OD: OD flow area 3.53" sq mid pipe 2 and 3/4 OD: OD flow area 5.94" sq crush bend is like concave banana boat 3.46" x 1.61. I going to eyeball call it 1/2 of a 3.2 inch OD pipe: 4.02" Sq clearly the stock header where there is the MOST energy is the primary restriction in the system. Gas Law and a heat delta of say 300 degrees, don't know college was in the 70s with a slide rule, starts at absolute zero: so say 60 percent of the original gas volume when the exhaust hits the crush.... not an issue, but it is a restriction none the less and somebody going to LT and off road pipes probably should look at the old slide hammer and a brazing rod.
12-11-2016, 05:19 PM | #37 |
No, I was just trying to point out how ugly the stock pipe is, in hopes to convince you to pull the trigger and buy a nice after market exhaust!
I just shot some sound clips of the Borla set up I have, obviously it will be a little different for you if you want to keep the stock muffler, but I can confirm that it sounds much better (deeper, louder) makes the car really sound sweet compared to when I just had the aftermarket axle back with the stock mid-pipes & xpipe! |
12-11-2016, 05:21 PM | #38 |
Sound clips as promised:
This is the Borla S-Type w/NPP (11924) along with the upgraded 2.75" Borla mid-pipes and x-pipe (60610). https://youtu.be/lZ8TUMHxgMw |
12-11-2016, 05:33 PM | #39 | |
I have the Borla s type and corsa x pipe on my c7 corvette. I went corsa with my camaro because I was kinda pissed that the s type was the same volume as the npp that was on my vette originally. Ironically....I feel like the corsa extremes are the same volume has the npp that was on my camaro : ( I was considering the Borla mid pipes that delete the sencondary cats, but I'm Trying to hold out to see what corsa has to offer. My vette sounds straight up mean with the Borla s type and corsa x pipe. |
12-11-2016, 05:39 PM | #40 |
sounds great.
12-11-2016, 05:45 PM | #41 | |
Thanks great man! I love how both Corsa & Borla sound, it's not too loud when you are cruising, there's zero drone, and when you stomp on it they just sound nasty!
I went with the 60610 for the mid-pipe & x-pipe set up because I didn't want to risk deleting the secondary cats and running into any emissions testing issues since VA tests you every 2 years. But hey, if you want a little louder you can always try to exchange your S-Type out with the Attack! Just try to trade with someone that did the opposite and went louder than they wanted to. I bet your vette sounds sick regardless though, they are pretty loud already from the factory. Quote:
12-11-2016, 05:50 PM | #42 | |
Where in va are you tested? I'm in Hampton roads and we don't have any testing thank god. Edit...just saw you're in nova. |
