TireRack
Old 06-17-2019, 08:14 PM   #1
Black 6.2L SS
Black 6.2L SS's Avatar
Drives: 2014 1SS/RS, LS3, NPP
Benefits of X pipe versus H pipe?
So I keep reading about some guys changing out the H pipe to an X pipe and others not doing so. I looked under my car (NPP) and it seems pretty clear that I have an H looking pipe after the cats. The crossover part is pretty small but it doesn’t appear to cause a restriction....the air just flows past the connector part and out the back.
So I’m wondering, why change it? Is it because of the firing order and exhaust pulses getting jammed up or something? Better sound?
I think my factory pipes are 2.5” so maybe when guys increase to 3” it’s just better cross flow to put in a 3” X pipe as well?
Thanks in advance for the ongoing learning.
Black 6.2L SS is offline   Reply With Quote
Old 06-17-2019, 10:03 PM   #2
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
H pipe for old v8 sound and more low end tq. X pipe for more exotic sound, and higher reving and a bit more power, maybe. Don’t do a 3” x pipe with a 2.5” exhaust.
VR Baron is offline   Reply With Quote
Old 06-17-2019, 11:24 PM   #3
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
There is zero performance gains switching from one to the other. As mentioned the x pipe gives you a higher tone while the h pipe is slightly deeper.
rontammy0 is offline   Reply With Quote
Old 06-18-2019, 07:34 AM   #4
Benman
Benman's Avatar
Drives: 13 IOM 2ss RS manual
This is the main reason I went to the X pipe, connected to factory NPP mufflers. Love the sound.
Rectangular Dollars will beat Cubic Inches
Benman is offline   Reply With Quote
Old 06-18-2019, 07:44 AM   #5
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
LOL both of my cars utilize the stock 2.5" NPP and made more power then anyone else's bolt on set up. My current set up on the C6 is the same 3" all the way to the stock axle back and makes 562 at the wheels NA SBE LS3. Not sure why you would direct a guy not to use a 3" X pipe? Please show me how much power he has left on the table. I dropped my whole muffler system on the C6 for last dyno and made zero change when it was still bolt ons......
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 06-18-2019, 08:10 AM   #6
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Gimmick....stick with you H.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 06-18-2019, 11:01 AM   #7
VR Baron
VR Baron's Avatar
Oops. Miss read your post. Thought you wanted to use a 3” x with a 2.5” catback
Old 06-18-2019, 11:31 AM   #8
lazerlemonta
Drives: 2010 C6 1LT
[QUOTE=VR Baron;10547552]Oops. Miss read your post. Thought you wanted to use a 3” x with a 2.5” catback[/QUOTE
They both used 3" to 2.5" and my C6 still utilizes this set up
Best MPH 134.82
Old 06-18-2019, 11:59 AM   #9
VR Baron
VR Baron's Avatar
[QUOTE=lazerlemonta;10547598]
Ok. Didn’t know gm would use 3” pipes and x pipe and neck down to 2.5 st the mufflers? Don’t see the point of that. But method in the madness as they say
Old 06-18-2019, 12:04 PM   #10
lazerlemonta
Drives: 2010 C6 1LT
[QUOTE=VR Baron;10547620]
Miss understanding. GM uses 2.5" full exhaust. Your header collector is 3" so use 3" all the way back to the axle and reduce to the stock 2.5"
Best MPH 134.82
Old 06-18-2019, 12:40 PM   #11
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
X pipe gave mine a slightly higher pitch sound, I like it
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 06-18-2019, 12:44 PM   #12
VR Baron
VR Baron's Avatar
[QUOTE=lazerlemonta;10547625]
Ah. Looks like at your power level 3” might help. At my 439 hp level mine didn’t do squat but made a deeper tone, and got a great deal on it. Necking down to 2.5” can’t see how it helps to have 3” in rest if system, peer wise. I see you’re point to fit headers. But plenty of 2.5 “ catbacks to fit to headers. But if it works, cool!
Old 06-18-2019, 12:52 PM   #13
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I installed a full Z28 NPP on mine with a X Pipe from a C7 Corvette, if you PM me your cell number I'll send you a sounds clip from NCM. Also have long tubes and HF Cats
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 06-18-2019, 01:30 PM   #14
lazerlemonta
Drives: 2010 C6 1LT
[QUOTE=VR Baron;10547680]
If your buying an X or H pipe per say, you buy the next best thing right? So 99% buy the 3" with future plans of completing the 3" system. No sense limiting yourself to 2.5" exhaust.
Best MPH 134.82
