07-01-2019, 11:01 AM | #1 |
3D Renderings and such...
Floaty feeling after drop/alignment
Hey all,
I had Eibachs installed on Saturday and the shop then aligned the car on a Hunter rack. It was the end of the day, so when they wrapped up, I was told that if there are any issues with the alignment, that I could bring it back in this week and they would take care of it. About a block away, I noticed that the steering wheel was cocked slightly to the left (3-5 degrees) so I was already planning to take it back to them. Further down the road, as I was getting on the freeway, I noticed the car felt a little, for lack of a better term, floaty - as though the car was losing traction, but not...if that makes sense. It felt like the car was fishtailing, but not out of control, just like the road was a bit slippery. Has anyone who's lowered their MRC cars experienced this? In all my searching, I've seen little to no conclusive proof that the MRC needs any sort of reflash/relearn, so I suspect it's an alignment issue. But in my experience, most alignment-related problems usually result in steering wheel wobble or vibrations in the car. I'd appreciate any input/insight into the issue. I know the subject of lowering these cars is touchy, so if you disagree with it, let me have it..but actual, helpful input would be way cooler. |
07-01-2019, 11:46 AM | #2 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
It has been said before, but I will repeat... DO NOT LOWER A MRC car!!!!
The software is made to work with the existing spring rates and length. GM did their homework on this car and the roll center is where it should be for optimum handling with the factory MRC calibrations. Any alteration from that and you are sacrificing performance for looks. Some will disagree and say "my car runs fine on lower springs", but I don't agree.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
07-01-2019, 12:29 PM | #3 |
Drives: ISO ss 1le Join Date: May 2018
Yeah u done messed up, the sensors are now thinking they’re an inch compressed, sending a constant rebound signal to the shocks. No bueno.
07-01-2019, 12:37 PM | #4 |
Any idea what would have caused it to happen on my car and not on the dozens of other cars that have had the same springs installed? Can't imagine people are out there driving their cars and thinking that's OK.
07-01-2019, 01:11 PM | #5 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
I'm not convinced the shocks are that sensitive.
If you steering wheel is off - means they didn't do a very good alignment in the beginning. I'd lean on excess toe out. Did you get a post alignment sheet with the numbers? Post and folks might be able to assist. Nonetheless, the alignment is off. Also post a pic of your lowered car! I think mine would look 100% better with an inch drop...
07-01-2019, 01:16 PM | #6 | |
Here's a side shot of the car post-lowering! |
07-01-2019, 01:30 PM | #7 |
Drives: 2017 SS 1LE Join Date: Sep 2011
Meh, don't listen to the naysayers. They are usually the ones who don't have direct experience and are just trying to justify their own opinions. Get the car properly aligned then report back..
07-01-2019, 01:37 PM | #8 |
Pay attention to the rack as well. Any change in rack from stock will affect handling as well.
Current:
07-01-2019, 02:16 PM | #9 |
Drives: 2018 Camaro SS 1LE Join Date: Sep 2018
Could also be tramlining.
07-01-2019, 02:21 PM | #10 |
07-01-2019, 03:15 PM | #11 |
I'm surprised people want to lower the SS 1LE. It has a nice stance in stock form with less wheel gap and more flush wheels to fender than most other performance cars already.
About the only MFG. who does it better is Porsche. Have you seen stock Ferraris or Lambos? This is mine stock... Compared to... I think GM have come a long way
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 Last edited by TRZ06; 07-01-2019 at 03:31 PM. |
07-01-2019, 04:42 PM | #12 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
The 1LE Eibach springs are supposed to lower the car about 19-20mm, which is a fairly decent deviation from factory. |
07-01-2019, 05:03 PM | #13 | |
The tech that installed my springs was familiar with MRC and took care when installing, but beyond a software flash, is there anything he could have done? |
07-01-2019, 05:32 PM | #14 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Maybe silly suggestion, but is tire psi too high?
