Roto-Fab
Old 08-19-2015, 02:18 PM   #1
White1LE'15
White1LE'15's Avatar
Drives: 2015 Camaro SS 1LE
1LE Hood Care
Hi all... new to the forum and to the Camaro world. Loving my 1LE I picked up a couple weeks ago.
I'm wondering what everyone uses on their black hoods to keep it clean and looking nice. After washing mine multiple times I have streaks in the vinyl that look like water marks. Does anyone use a specific vinyl cleaner?
Thanks
2015 Camaro 2SS/RS 1LE Summit White, NPP Exhaust
White1LE'15 is offline   Reply With Quote
Old 08-19-2015, 04:40 PM   #2
Dtowndog420
Drives: SBM 09 G8 GT/RH 15 SS 1LE
Distilled water seems to work best!!!
Dtowndog420 is offline   Reply With Quote
Old 08-19-2015, 04:52 PM   #3
Andoskyy
Drives: 2015 Summit White 2SS/RS 1LE
This should be your bible.
http://www.adamsforums.com/topic/134...vinyl-stripes/
Andoskyy is offline   Reply With Quote
Old 08-19-2015, 04:53 PM   #4
Airway Monkey
Airway Monkey's Avatar
Drives: 2015 2SS/1LE
Adam's SVRT is the best....hands down. Removes most of the spots and protects it as well...just went out and took 2 pictures...car hasn't been washed in 2 weeks and has seen some heavy rains.
Note: the SVRT gives the hood more of a satin appearance. But I prefer the satin "shine" to the dry vinyl appearance that looks terrible IMHO with all the water spots and marks.
Airway Monkey is offline   Reply With Quote
Old 08-19-2015, 04:56 PM   #5
Airway Monkey
Old 08-19-2015, 05:00 PM   #6
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
+1 on Adams SVRT
CamaroDreams76 is offline   Reply With Quote
Old 08-19-2015, 06:30 PM   #7
ASimmons04
Drives: 2015 AGM 2SS RS 1LE
Glad I saw this post! So much great info on this site! Should be picking up my 1LE next week!
ASimmons04 is offline   Reply With Quote
Old 08-19-2015, 06:34 PM   #8
PwrCrusr
PwrCrusr's Avatar
Drives: 2014 1LE
Another option is the Chemical Guys Meticulous Matte Detailer.
http://www.chemicalguys.com/Meticulo...spi_995_16.htm
I wash like normal, raise the hood to drain the water off and wipe it dry. Then spray and wipe it down.
2014 1SS 1LE SIM RS NPP
PwrCrusr is offline   Reply With Quote
Old 08-19-2015, 09:35 PM   #9
Trip
Trip's Avatar
Drives: 2015 White RS 2SS 1LE
If you wash it normal and dry it with a towel, it will look real nice.
If you have marks on it, oil or grease or something, then you should use the Adams VRT or something similar, it'll be shiny for a while but it wears off and the whole hood should be consistent. At least that worked for me when I had some fingerprints or something that I couldn't get off on there. Or just keep using the VRT if you like the look.
Trip is offline   Reply With Quote
Old 08-19-2015, 10:35 PM   #10
silverbullet415
silverbullet415's Avatar
Drives: 2018 Camaro ZL1 1LE
I use chemical guys
silverbullet415 is offline   Reply With Quote
Old 08-19-2015, 10:52 PM   #11
Galaxy_Stranger
Drives: Black 2013 2SS LS3 1LE
Anybody know what Plastidip will do to a vinyl hood?
Galaxy_Stranger is offline   Reply With Quote
Old 08-19-2015, 10:55 PM   #12
Ventura 2015 1LE
Ventura 2015 1SS 1LE RS
Ventura 2015 1LE's Avatar
Drives: 2015 2SS 1LE
I use chemical guys as well. I don't need to use it every time. It lasts for a month with the car being garaged. I wipe down the car weekly and rarely need to soap up the car and wash. What I use is a spray-on detailing wash. Most are fine and used most off the self brands. Right now I did go to the local detailing shop and purchased a spray-on wash and has worked the best. Its pink in color brand name is 3-D.
Ventura 2015 1LE is offline   Reply With Quote
Old 08-19-2015, 11:02 PM   #13
Ventura 2015 1LE
As far as Plastidip on the vinyl hood that would be somewhat of concern. That is just me shooting from the hip. Think about its vinyl and now your putting on a plastic coating, its not like paint on metal which would peel with effort. Now with vinyl I would think its somewhat porous and would be very difficult to peel Plastidip off..
I might be wrong. I would go to the local vinyl sticker shop and ask or buy a small piece and stick it on some metal then apply the Plastidip and then peel off to see if it works or not.
Worst thing to do is spray it on and regret you did because of problems..
Just maybe someone has actually done this and will chime in
Old 08-19-2015, 11:18 PM   #14
tmcclint
tmcclint's Avatar
Drives: 2014 AGM 2SS/RS 1LE
I use Meticulous Matte from Chemical guys as well. My Camaro is garaged so I just make it a point to use it after I wash the car and the hood is at room temp. I've never had any streaks at all and it's been nearly two years since I started using it.
2014 2SS RS 1LE
tmcclint is offline   Reply With Quote
1le, clean, hood
