06-08-2015, 12:35 PM | #1 |
Drives: 2015 Camaro 2SS 1LE Join Date: May 2015
CAI-Looking for honest answers
I'm checking to see what brand of cold air intake the general masses of 1LE owners recommend. Looking for honest answers such as:
Is there really a noticeable difference in performance or is it just imagination? What brand gives the most bang for your buck? Any problems with the CEL after installation? I've heard so many conflicting stories from the guys I work with that I thought this would be the place to get some honest answers. Thanks in advance! |
06-08-2015, 12:40 PM | #2 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Welcome to C5 this subject has been beaten and beaten to death, I would suggest you search the 100's of threads and decide for yourself.
IAT's are key, arguably, CAI Inc and ADM make the best under the hood systems. If you have an option to go over the radiator, I would recommend that over them all.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
06-08-2015, 12:51 PM | #3 | |
Drives: 2000 Camaro SS Join Date: Feb 2010
THE Air Intake Thread |
06-08-2015, 01:03 PM | #4 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
There is also the Chevy Performance Z/28 CAI kit. Looks great. Performs great. There are a couple of discussion threads on here with that intake as well. One has dyno results from a member on here too.
06-08-2015, 01:11 PM | #5 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
To me, the spreadsheets tell the tale. These systems are fairly expensive (around $400). The average HP gains just do not seem worth it to me. In my opinion, if making a noticeable amount of HP is the goal, you need to save your money and put it into real parts like heads, cams, and a tune, or a supercharger or turbo if forced induction is your thing. Yes these modifications will void ones warranty, where a CAI may not, but then you will really have something. I find this equipment on its own to be a huge waste of money, much like similar systems by K&N were back in the day.
06-08-2015, 02:49 PM | #6 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
What works great is the CAI ,with the Apex race scoop and washer relocation set up . You will absolutely notice a bump in power. It is a well proven set up that just plain works.
OLD GUY FLYING FAST AND LOW
06-08-2015, 02:57 PM | #7 |
Drives: 2011 2SS/RS LS3 Join Date: Jan 2015
Running a rotofab on my ss, with the scoop and washer relocation. No issues to date and I do like the change to the sound. Just make sure you buy a quality system and you'll be fine.
2011 2SS/RS LS3 Rotofab CAI/scoop/washer - FE4 conversion - Pfadt ZL swaybars - BMR endlinks - Hurst short shifter - RKSport spoiler |
06-08-2015, 06:21 PM | #8 | |
Drives: 2015 Camaro SS/1LE Join Date: May 2015
http://www.camaro5.com/forums/showthread.php?t=411545 http://www.camaro5.com/forums/showthread.php?t=405258 Let us know what you decide on.
2015 2SS/1LE/RECARO/NPP/RS/NAV
06-08-2015, 07:09 PM | #9 |
06-08-2015, 07:26 PM | #10 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
I have CAI now and have nothing bad to say about it. It's great and many prefer the sealed, shielded box. I had Roto-Fab on my previous Camaro, nothing bad to report there either. I'm however selling my CAI and installing the Chevy Performance Z28 intake. Not because it's magical and will give me a ton more HP, but because I like the OEM look and feel of it
"Make yourself sheep and the wolves will eat you"
06-08-2015, 07:59 PM | #11 | |
Drives: 2014 Camaro Red Hot 1LE NPP Recaro Join Date: Jun 2014
Did they test at the 'ring, did chevy use them as the supplier for the Z28, me not think so. OEM Z28 Cold air located at your nearest chevy dealer. |
06-08-2015, 08:10 PM | #12 |
Drives: 2015 Redhot 1LE Join Date: Feb 2013
best cai is front bumper delete with cai delete youre welcome.
06-08-2015, 08:49 PM | #13 |
The Z28 intake is not a bad intake, definitely better than the stock SS intake, but just because it came from GM doesn't mean it is the best thing out there. Intakes, like most any part designed by the OEM, have to take on considerations that the aftermarket does not. There are many factors at play for the OEMs with pesky things like decibel level and cost trumping max efficiency. GM actually has worked with CAI Inc on the development of performance intake systems that were featured on vehicles at the SEMA Show for the past couple years. The owner of CAI Inc is a former GM engineer.
06-08-2015, 09:01 PM | #14 |
Well, congrats OP on starting a firestorm LOL. And in case you're wondering what else gets our community worked up? Catch cans ( I have that too, elite engineering from Apex). Welcome to the club OP. Just remember, cold air and catch cans are the "politics and religion" topics of C5
Thread Tools | |
