06-13-2023, 05:02 PM | #1 |
Drives: 2018 Chevy Camaro ZL1 1LE “ZLR” Join Date: Sep 2019
Need wheel and tire recommendations for high HP ZL1
I have a built 2018 ZL1 1LE making 980 whp on 93, 1300 whp on E85, and 1500 whp on C16. My current drag pack is 15" Belak beadlocks with M/T Street R 275/60R15. The car has a 9" rear with 15" brake conversion, DSC sport controller with their Tractive active coilover suspension, and MoTeC ECU handling the boost and traction control.
I'm looking at getting a street setup for 40/60 rolls with Forgeline beadlocks in 17/18 x 11" rear and need some guidance on tires between Nitto 555r2, Nitto NT05R, Toyo r88r or RRs, or M/T Street R. Based on what I'm reading, I should be able to fit a 325 tire. Max tune for the street is 1300 whp on E85. Last edited by ArmedTrashPanda; 06-13-2023 at 05:34 PM. |
06-13-2023, 05:39 PM | #2 |
I think if you go 19” you can run a 335/345 R888R out back which would probably be the best bet for roll racing. I love the high speed stability of that tire over typical drag radials but that’s just me. On the strip, I just switched to 325/50/15 ET Street R on D5 Beadlocks and hope to give those a rip at my local track soon.
Just my 2 cents.
06-13-2023, 08:07 PM | #3 | |
06-13-2023, 09:17 PM | #4 | |
18” 335/30ZR18 RIM: 11.5-12.5 OD: 25.9”. WIDTH: 13.5” 19” 345/30ZR19 RIM: 11.5-12.5 OD: 27.2”. WIDTH: 13.8” The 19” is taller which will help blunt the torque (a little lol) and is a tick wider. If you can fit that, that’s my choice and likely my choice next year. I love the OEM 20” SS/1LE wheels but there’s just not enough sidewall for crappy Mass roads. I’m currently running 315/30/20 R888R on the street and like them but could use more sidewall. Extra 30mm width won’t hurt either.
06-14-2023, 06:36 AM | #5 |
Drives: 2016 Camaro 2SS "Convertibobble" Join Date: Mar 2022
And I thought my stock SS was "powerful"...
O M G
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp) '99 4Runner 367K '94 ST1100 146K |
06-14-2023, 07:40 AM | #6 |
Don't worry Chief, there's a reason he is after tire recommendations. No size or compound is able to hold that power on the street where you'd want somewhat normal, usable tires, so his car is just a smokier burnout machine
06-14-2023, 08:09 AM | #7 |
Awww, how cute!
2018 Camaro ZL1 1LE "ZLR" 1500 whp built by Prospeed Autosports | LME 416 Dry Sump Long Block LT4 8500 RPM | LME Intake Manifold | Prospeed Custom 1500 Precision Twin Turbo 6466 Gen 2 | RTS RXD 6 spd Billet Seq Gearbox | RPS Triple Carbon Clutch w/ Tilton Slave | ARH catless exhaust | DSS 9” Rear Kit | Carlyle 15” Conv | MoTeC M180 ECU w/ Air Paddle Shift | Avio Race Steering Wheel | MoTeC C1212 Dash | RPM 6-pt Roll Bar | Belak Beadlocks | M/T 275/60R15 Street Rs | DSC Tractive Coilvers w/ Cntrl | BMR Chassis | Cobra CF Seats | Rear Seat Delete | Anderson Comp CF | APR CF Wing & Rear Diffuser
06-14-2023, 09:21 PM | #8 |
Isn't it Just making a joke in good humor, I know your car makes 2x more power than mine.
06-14-2023, 09:37 PM | #9 | |
@ArmedTrashPanda: what do you think about my 18”/19” tire thoughts? I just can’t picture trying to run my 15” Beadlocks on the street.
06-15-2023, 10:46 AM | #10 |
All good! On a serious note, I do think I can put the power down with the right tire. The MoTeC ECU gives me very granular control over the boost, and its traction control is second to none. The HP numbers I quoted are at max boost. I have 10 different boost control settings on my steering wheel that I can dial up/down based on the road conditions. The DSC sport controller with active suspension also is also a big improvement over the DSSVs.
06-15-2023, 10:50 AM | #11 | |
Rear: Toyo R888R 335/30ZR18 - wheel width 11.5-(12.0)-12.5, O.D. 25.9”, Width 13.5”, Revs Per Mile 801 Front: Toyo R888R 295/30R19 - wheel width 10.0-(10.5)-11.0, O.D. 26.0”, Width 11.8”, Revs Per Mile 798 __________________________________________________ ___ Rear: M/T Street R P325/35R18 - wheel width 10.0-(11.0)-12.0, O.D. 27, Width 13.1” Front: Toyo R888R 285/35R19 - wheel width 9.5-(10.0)-11.0, O.D. 26.9”, Width 11.4”, Revs Per Mile 773 __________________________________________________ ___ Based on these tire combos, I'm considering an 11.5” rear wheel and 10.5” front. I need to confirm if a 1” difference in O.D. between the front and rear tires will cause an issue with the traction control and/or ABS.
06-15-2023, 11:55 AM | #12 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I love mine... they hook decent in 2nd at 730rwhp... and im running 345/30/19
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
06-15-2023, 12:20 PM | #13 |
That looks killer!
06-16-2023, 09:12 PM | #14 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Nice socal, what are you running up front?
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
