11-03-2021, 07:12 AM | #1 |
Drives: ZLI 1LE; 992 S; GLE 450, Denali HD Join Date: Sep 2019
18" Michelin Slicks
I'll be running MIchelin slicks for the first this this weekend. 30/35/18 Front, 30/68/18 rear.
Anyone have a good reference for tire pressures? Thanks for the input guys and gals. |
11-03-2021, 08:50 AM | #2 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Anyhow, I have had good success running those at 25 PSI cold. Pirelli slicks I run at 28 PSI cold. The reason for this is that the MICHELINS have a stiffer sidewall than the pirellis. BOTH these tires like ALOT of camber. I run -3.6 in front and -2.4 in the rears. The TOE IN TOE OUT setting should be basically NEUTRAL. Also the Michelins are a little WIDER than the pirellis of the same size. The Michelins to me seem a little stickier tire than the pirellis. The pirellis will last longer.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
11-05-2021, 06:01 AM | #3 |
OOps, typo - correct 30/65/18
Thanks for the feedback. I've been running Pirelli's as well - same cold pressure; 28. Get them to 32-34 psi, they are consistent. I'll start them at 25 as you suggested. Does anyone ave experience with Hoosiers A7/R7 - feedback I received for A7 is start at 40 psi - seems way too high for cold starting pressure. Can;t find any info from the web. |
11-05-2021, 06:12 PM | #4 | |
Drives: 2018 ZL1 1LE Join Date: May 2020
11-06-2021, 08:00 AM | #5 |
07-03-2023, 10:55 AM | #6 |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
What size wheels are you running with 30/65/18? Have 18x11” Apex and considering trying Michelins.
07-03-2023, 11:31 AM | #7 | |
Run them at 23-24 PSI cold. The slicks like as much camber as you can throw at them.
