11-20-2020, 11:03 AM | #29 |
ill show him these!
11-20-2020, 11:14 AM | #30 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I'm highly skeptical of studs that cost $1. Sounds like a sheared stud or lost wheel waiting to happen.
As for other extended studs, the studs off of the pickup trucks are the same grade material and everything as the Camaro and are 8mm longer. I made that swap a few months ago. Even fit using the stock lug nuts and wheels without punching through the face of the lug nut like the ARP ones would if anyone is switching between aftermarket and OEM wheels frequently. GM part number is 11588810.
2017 SS 1LE.
11-20-2020, 11:39 AM | #31 |
Drives: 2013 C6Z06 Join Date: Nov 2016
11-20-2020, 12:25 PM | #32 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Yeah, but only +~$200/set. 305/19 660s are under $300/tire but then the 315/18s are closer to $350/tire. At <$300 I was prepared to risk it and hope the 660s worked out, but at $350 I'll go w/ A052s, which are just under $400.
11-20-2020, 12:30 PM | #33 |
Can't argue with the proven tire. They are way too expensive for me to even consider for TT with how fast they cord. Plus I don't have 18s. Though it seems if you want to win, you better be on them.
02-05-2021, 11:15 AM | #34 |
so are most guys with 19s running staggered setup or square?
02-05-2021, 12:24 PM | #35 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
I've run 18" and 19" on my ZLE. For me, the wheel size is dictated by the fastest 200tw tire. This probably sounds crazy and backwards, but when it comes down to it I'm just doing what is required to get the fastest tire on the car.
I am starting this season with 18x12 and 315/30-18 A052 all-around. On the same wheels I could also run RT660 or CR-1 in the same size. (I am not on stock struts) I don't know what most people are doing with 19's, but my last 19" setup was 19x11 +40 square, with camber plates you can run the front with 25mm spacers and still keep the tire off the SS fender. This is a pretty tight squeeze, anything wider requires strut work. |
02-05-2021, 12:28 PM | #36 | |
I'm stock but will probably go with camber plates up front to help with clearance, grinding a bit of strut for more clearance wouldn't bother me.
02-05-2021, 12:49 PM | #37 |
yea i got 2 quotes on 19s both were 19x10 19x11 squared seems to be more rare for some reason
wanted to do 2853019 3053019 but no options only 2853519 3053019
02-05-2021, 12:59 PM | #38 |
My 18x12's are BCs with custom offsets. It's not really viable unless you are running offset MCS struts and/or plan to do some fender cutting. With stock struts and fenders you and do 19x11 without too much trouble.
02-05-2021, 07:05 PM | #39 |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
Krops, I think you'll either need to do factory ZLE, custom or go APEX to get 11" front wheels. And frankly, I wouldn't go with 10" in the front unless you couldn't go wider because of competition rules.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
03-16-2021, 09:42 AM | #40 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
I have the apex arc 8 with 19x10 et 20 and 19x11 et 43 and i run a 285/35 front and 325/30 rear for track days. I haven't had any issues. I love the tire setup. I'm considering buying two more 19x11 wheels for the front just for go square and rotate.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
03-16-2021, 10:41 AM | #41 |
yea even with 19s unless you are squared the sizes are kind of wonky lol what tires are you running in that sizes?
03-16-2021, 11:03 PM | #42 |
Drives: 2018 ZL1 1LE Join Date: May 2020
I went with 18's on my ZLE to allow a better selection of slicks/R-comps. the 18" combo also weighs about 37lbs less than the stock 19's. I went with BC forged due to them being fully forged. Apex wheels are flow formed and not quite as strong. I know a lot of people have successfully used apex wheels for a while with no problem, but i didn't want the risk. I think a lot of people go with Apex based off price point. They sent me an email and will be offering a discounted rate on their new 18" setup for Camaros coming out soon. if interested shoot them an email and ask about the pre production price.
