09-01-2020, 09:25 AM | #1 |
Drives: 23 ZL1 6speed Join Date: Aug 2020
6MT - is this normal?
Hopefully this does not come across as one of "those" first time posts... I just purchased a '17 Camaro 2SS with the 6 speed a couple of weeks ago. I've probably put only about 700 miles on the car so far... ~500 of which were from driving it home from the dealership.
To the question - is it normal for these transmissions to be quite notchy? I've noticed that the car is quite particular on how it wants to be shifted, and has a fairly high engagement point. Those things do not concern me - I understand that often comes with performance cars and the engagement point is just something to get used to. However, it is notchy going into all gears..regardless of RPM level, shift speed, acceleration, etc. It seems to shift smooth, it is just you can feel it going in/out of gears. This is not my first manual, but it has been ~5 years since I've owned a manual car..1-2 years since I've driven one prior to buying the Camaro. I've read that the 1-2 shift is common to be notchy..which doesn't concern me either. That can be found in many cars. |
09-01-2020, 09:46 AM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
This Tremec is the best tranny i've had. MT82 was just OK but the manual in my Genesis 3.8 was a flaming POS. They all have they're assorted nuance's, or nuisances? The A8 guys have a mystery shudder that is still unresolved.
09-01-2020, 10:29 AM | #3 |
Drives: 2019 Camaro 2SS manual Join Date: Feb 2020
Just wondering, has the car been modded or did it come with a short throw shifter? The short throw shifter can feel quite different if you haven't used one before.
09-01-2020, 10:33 AM | #4 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
It has a 'positive engagement feel'...not notchy. I would add a transmission fluid service to your 'new car to-do' list. It's not expensive and will make a small difference in shift feel. Especially when it's cold. Go with the Tremec fluid https://www.tremec-store.com/collect...smission-fluid or Redline D4. Have fun!
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
09-01-2020, 10:36 AM | #5 |
09-01-2020, 10:47 AM | #6 | |
Riiiight . Does this mean that I'm not the only one with this sort of experience? I have been looking into changing the transmission fluid.It looks like it is a simply drain and refill? |
09-01-2020, 11:12 AM | #7 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Wait till it gets cold outside. I have the baby Tremec and I think the notchy feeling comes from a combination of synchro rings, gears, and from the shifter assembly. It feels more positive than the old style with the rods and nylon guides. I did change the fluid after 10k. If you are unsure go test drive one and compare.
09-01-2020, 11:45 AM | #8 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
If one is not used to it, it can definitely feel odd, but personally I like mine. My RX-8 and C7 both felt like that. Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
09-01-2020, 11:53 AM | #9 | |
09-01-2020, 12:00 PM | #10 |
Camaro Time
Drives: 2021 Camaro 1SS/1LE Join Date: Sep 2019
Tremec
The TR6060 is a finicky tranny. Mine was horrible 1st through 3rd, and forget about downshifting into 2nd. Seems they are either perfect or they are trash
09-01-2020, 12:04 PM | #11 | |
And agreed the Tremec is one of the best out there.
09-01-2020, 12:09 PM | #12 |
09-01-2020, 12:11 PM | #13 |
I really haven't encountered the reported bog as I'm not trying to launch it but yeah it's a def reported "issue" peeps have with the Tremec in this car.
09-01-2020, 12:14 PM | #14 |
Drives: 2018 Hyper Blue Camaro 1SS Join Date: Sep 2019
My engagement point starts right about in the middle of the full arc of clutch pedal travel. It's all relative I guess but where does yours engage OP and what do you consider "high"? Also, as asked above what is your mileage as it may affect engagement if your clutch is worn.
1LE Replicas / Solo Axleback Exhaust/ Street Scene Front Splitter / Diode Dynamics Smoked LED Side Markers / OEM Smoked Tails & Third Brake Light / OEM Illuminated Door Sills / OEM ZL1 Side Skirts / OEM ZL1 Spoiler / OEM Black Badges / GM CAI / Soler Engineering TB/TC / Katzkin Leather / 20% Tint
