Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 10-19-2018, 08:37 PM   #1
MX621
MX621's Avatar
Drives: 2014 z28
Gen6 ZL1 front rings?
Reading around still learning about these cars. I read on a racing brake post that the z28 and gen 6 zl1 brake systems are basically the same except zl1 has iron rings. I know the hats are diff on the gen6 so it won’t be a direct swap. But would it be possible to run the gen6 zl1 front rings on the z28 hat? Seems the zl1 rotors are 360$ or so each.
MX621 is offline   Reply With Quote
Old 10-20-2018, 05:53 AM   #2
BJJKRIS
BJJKRIS's Avatar
Drives: 2015 Z/28 #18
Try looking up part number. If they're identical then the answers clear. Planning on running the iron rings in hopes to save a bit on a brake job later?
BJJKRIS is offline   Reply With Quote
Old 10-20-2018, 08:26 AM   #3
rh96ss
Drives: 2013 ZL1 Convertible/2015 Z/28
Look like different size rotors.
From Chevrolet Press releases:
2015 Z/28
Rotor diameter x thickness, front (in / mm):
15.5 x 1.4 / 394 x 36
Rotor diameter x thickness, rear (in / mm):
15.3 x 1.3 / 390 x 32
2017 ZL1
Brake Rotor Size (in / mm): Front: 15.35 / 390 vented, with six-piston monobloc calipers
Rear: 14.4 / 365 vented, with four-piston fixed calipers
And what about rears? Iron up front and carbon in the rear?
rh96ss is offline   Reply With Quote
Old 10-20-2018, 12:30 PM   #4
MX621
MX621's Avatar
Drives: 2014 z28
I know you can run the z28 front rotors using a zl1 caliper on the racing brake ccr kit for the gen6 zl1. I’m being overly optimistic but would be a great alternative.
