04-02-2016, 05:46 PM | #169 | |
Drives: 1LT RS 2.0T 8A HD Join Date: Feb 2016
Exactly! The A10's biggest performance advantage is simply having one more speed range for the pwerband to operate within for track purposes, and therefore allowing a higher engine speed immediately following each upshift for drag purposes. Of course, the biggest efficiency gain is having a third (holy crap) overdrive ratio. |
04-02-2016, 10:25 PM | #170 |
Est.1775
Drives: '15 Challenger Hellcat (sold) Join Date: Sep 2009
Dodge won't do anything significant. Lifespan ends in 2018. I'm excited either way you look at it over the next 1-3 years.
04-02-2016, 10:51 PM | #171 | |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
04-06-2016, 10:15 AM | #172 | |
Drives: 2018 ZL1 6M, Silverado High Country Join Date: Oct 2008
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof 2019 Silverado High Country, Daily Driver |
04-06-2016, 10:29 AM | #173 | |
This MT review pretty much says the same things we have: http://www.motortrend.com/news/2015-...c-first-drive/
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
04-06-2016, 01:11 PM | #174 |
Drives: Charger Hellcat Join Date: Apr 2016
Just thought I'd chime in as I currently own a Charger Hellcat.
I'm looking to downsize at some point but I still want 4 seats, so the ZL1 is looking very interesting. I'm probably going to wait at least a year to see if Ford releases a GT500 before making a final decision though. I'm very excited about the A10. I suspect the final verdict will come down to how smart the software is. The ZF 8 speed used in the Hellcats is used in a wide variety of cars and it's up to each manufacturer to create a shift map. So the identical physical hardware in a Bentley Mulsanne shifts very differently from the same unit in a Hellcat. That said, I expect that GM will apply all they've learned from the A8 such that the A10 should perform well right from day one. (When I say "perform well" I don't just mean shift speeds at WOT, but also downshifting aggressively going into turns without upsetting the chassis.) As far as performance matchups go, I think the ZL1 should handily outperform the Hellcat. The Challenger has about 6.3 lbs/HP and the ZL1 has about 6.1 lbs/HP. The ZL1 has wider, more aggressive tires and Chevy has more sophisticated traction management than the Dodge does. In a straight line it'll be close but the ZL1 will have the edge; around a track the Hellcat will not even be in the same zip code, LOL. I speak from experience when I say the Hellcat is hard to launch well consistently. (Much easier on drag radials but I'm talking about stock tires.) So apart from the times set by magazine reviewers, in any street matchup I'd expect the ZL1 to win consistently. |
04-07-2016, 02:07 AM | #175 | |
Drives: 2013 2LT RS, 2017 ZL1 Join Date: Jan 2013
No clue how close a rolling start would be between the two. And yeah, on the track, the zl1 will be running circles around a cat. |
04-07-2016, 06:33 AM | #176 |
Drives: 2019 GT350 Join Date: Jan 2011
Listen getting a 640-707 hp car to stick on factory rubber is going to be a challenge regardless of whether you have 275s or 305s out back on a street tire. Unless the track has fantastic prep you are going no where quik.
Remember when the 12 ZL1 came out and most were running mid-high 12s, only very few were able to get the car anywhere near an 11-sec pass of factory rubber. This new ZL1 will have much more tq which likely will make launching even tougher. I'd expect this new ZL1 to run very similar times to the present CTS-V 11:70-12:00 on factory rubber, and 11:20-11:40s on a quality DR.
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot |
04-07-2016, 06:40 AM | #177 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
I'll take the non skinny tire car for $100 Bob.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
04-07-2016, 08:17 AM | #178 |
Drives: 68 ss Join Date: Feb 2016
jus hoping to see some of that copo know how filter down to the ZL -1
04-07-2016, 08:45 AM | #179 | |
Drives: 16 Camaro, 11 Stryker, 00 Explorer Join Date: Dec 2015
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015 3000 1/8/2016 (TPW 2/1) 3800 2/1/2016 5000 3/5/2016 |
04-07-2016, 10:08 AM | #180 | ||
Drives: 2021 Camaro ZL1 A10 Join Date: May 2013
I'm in the same boat as this guy. Quote:
04-07-2016, 11:20 AM | #181 | |
HAMMER PILOT
04-07-2016, 11:40 AM | #182 | |
Go back and read the ZL1 forum for actual results not the best of the best list. But even taking the list into consideration out of the thousands of ZL1s out there and the majority of their forum more interested in drag racing than track racing, we have 12 passes in 5 years? The conclusion is your car can have all the power in the world but unless you are running a true DR your chance for a great pass is very slim. All the power players including the last GT500, Hellcat, present ZL1 and future ZL1 need a DR or incredible track prep such as what can be had at a private track rental. Think of it this way if I go out and run a 13-sec pass in a car that is supposed to run 11s do you think I want to add that time to the list?
2019 GT350 RR
