01-08-2011, 04:38 PM | #1 |
Drives: 2012 Zl1 Camaro Join Date: May 2010
Tune after 4.33 gears
A question for you tuners out there..
If a gear swap to a 4.33 rear end is done will a tune make a difference on a V8 maunal 2010 camaro? I know with any mod a tune is recommend with a bolt on or nessary with say a cam swap, but with new gears how important is a tune? Can a dyno graph be used to prove a tune will give better performance, or can you only see it in a quarter mile time slip?? |
01-08-2011, 04:51 PM | #2 |
Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
don't see how a tune will do anything for you since you do your own shifting. I think a transmission tune would be necessary if you had an automatic.
Yeah, I'll get around to it...
01-08-2011, 05:02 PM | #3 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
I'm not sure if gears would affect the speedometer on the 2010 Camaro.
01-08-2011, 05:14 PM | #4 | |
Drives: 2008 Pontiac G8 GT Join Date: Nov 2009
2008 White Hot G8 GT
(new)499RWHP/474RWTQ Mustang Dyno (old)451RWHP / 498RWTQ Mustang Dyno 1/4=11.400@118.7 17" Drag Radials, stall, cam 1.77 60' 1/4=12.004@120.6 17" Drag Radials 2.03 60' 1/4=12.270 @118.3 on 18" All Seasons 2.08 60' SLOWHAWK[/URL] Tuned If you can't say anything intelligent, say something loud and stupid |
01-08-2011, 05:53 PM | #5 | |
Drives: 2000 Camaro SS Join Date: Feb 2010
01-08-2011, 05:56 PM | #6 |
Drives: First 9 inch-12 bolt IRS Camaro Join Date: Jun 2009
You will need to get your speedo calibrated,and it will dyno a lower number but should improve your times on a na car..
01-08-2011, 06:25 PM | #7 |
BAMF SS
In order for the speedo to work correctly, you have to change the values... and the only way to do that is with a new tune.
You CAN drive around with an incorrect speedo in a manual, if you would want In an auto, the speedo will still be off and so will the shift points
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
01-08-2011, 09:18 PM | #8 | |
Drives: VR ZL1 #259/Nissan 370Z NISMO Join Date: Aug 2008
Thank you! |
01-09-2011, 07:44 AM | #9 |
01-09-2011, 09:10 AM | #10 |
For what its worth, I took this from another forum. This is a quote by Power Ported Performance.
"Final drive ratio and gear ratios throughout the drivetrain affect power output (via efficiency if nothing else), as does the clamping force of a given clutch, the condition of the surface of the flywheel, the balance of the driveshaft, etc, etc." "The stronger the gear set, the taller the resulting power curve (and the shorter the amount of time the drivetrain requires to reach operating peaks). However, all other things being equal (efficiency, quality of install, all the other variables), no particular gear ratio (in and of itself) will generate better horsepower or torque readings than another UNLESS the ratios are so high as to affect the operation of the engine, or so low as to prevent the engine from achieving maximum volumetric efficiency (this last might occur - the other would be very difficult to pull off)." |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 | MarylandSpeed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 27 | 05-18-2013 10:01 PM |
Drawbacks of a mail order tune | herkman | Tuning / Diagnostics -- engine and transmission | 19 | 06-10-2010 09:58 PM |
Supercharger tuning: Why shop tune instead of tune with the S/C? | JProberts | Forced Induction - V8 | 10 | 12-28-2009 03:54 PM |
Lets play a game | 2SSRS@Gen5diy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 56 | 09-26-2009 09:08 AM |
LS3 goes 11`s Bonestock! | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 12-08-2008 09:10 PM |
