04-30-2020, 04:11 PM | #1 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I think I finally got the right combo... dyno results inside !
This winter I picked up a set of FED stage 2 heads, and had a cam ground by TSP to suit my needs. Went with Cometic .040 head gaskets and Johnson 2116lsr tie bar lifters. Had to use 4 different length pushrods to get the preload in spec. Needless to say, I'm a happy camper!!!
Also, once on the dyno, my tuner sensed that she was thirsty for more air. Picked up 16 hp with this 5 inch intake.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
04-30-2020, 04:30 PM | #2 |
Drives: Camaro Join Date: Oct 2018
Dang that curve stays right at 600 for a while if you can push it out more
04-30-2020, 04:37 PM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
600 rwhp, that is freaking awesome
You nailed the combination man, that thing has to fly. The intake tube looks bad ass too! Love the all Orange motor, reminds of the SBC/BBC days.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
04-30-2020, 06:13 PM | #4 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Nice!!
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
04-30-2020, 06:50 PM | #5 |
Holy crap Clark,that's freakin awesome! You nailed that one !! Must be a ton of fun to drive too.. Enjoy it.
04-30-2020, 06:56 PM | #6 |
Hell yeah clark! That’s a killer combo there. X1 loves cubes and rpm along with compression
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
04-30-2020, 07:11 PM | #7 |
Drives: 13' 1LE Join Date: Apr 2012
Wow !! Awesome numbers and combo! 600rwhp with ls3 heads and hyd cam on a 416! Love it!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
04-30-2020, 07:36 PM | #8 |
Drives: 2014 2SS/RS Join Date: Jan 2018
Awesome
2014 2SS/RS LS3/M6
04-30-2020, 08:27 PM | #9 |
Fyi... Late Model Throttle has a facebook page, they posted a cool pic and idle clip...
04-30-2020, 09:41 PM | #10 |
Sounds ****ing sweet!
05-01-2020, 08:51 AM | #11 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
damn 5” intake ftw! Awesome results!
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
05-02-2020, 04:39 AM | #12 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Awesome you did a test on the bigger intake tube. I was planning on testing that on my build.
05-02-2020, 08:07 AM | #13 |
Drives: 2010 Join Date: Aug 2018
Good Job Man.
05-02-2020, 09:47 AM | #14 |
Drives: 2010 SS L99 Join Date: Sep 2018
Very nice Clark!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
