03-08-2018, 08:30 AM | #15 |
He had same TRQ with stock intake Bo............ That dont add up lol
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
03-08-2018, 08:35 AM | #16 |
Drives: 99 camaro ss with a bolt on ls6 Join Date: Feb 2017
When you use a intake like this be prepared to spin it to atleast 7500. This is basic stuff you guys over look. You basically wasted your money on dyno time and tuning and our time posting a dyno hp curve that didn't even peak yet.
03-08-2018, 08:41 AM | #17 | |
03-08-2018, 08:41 AM | #18 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Oh... sorry for wasting your time. I hope you can apoligoze for wasting my time because this may be the dumbest most ignorant post I've ever seen on here.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
03-08-2018, 08:47 AM | #19 | |
03-08-2018, 08:52 AM | #20 |
Do you have your old sheet? I would like to see just how much more power from 6200 up your making. I bet your 70hp at 6900
03-08-2018, 08:53 AM | #21 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
but he lost torque when he had his cam install. going from the TSP engine dyno of that same cam his torque should not have been affected with the cam install.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-08-2018, 08:58 AM | #22 | |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Now if you can live with that..cool..if you want to fix it now? only way if not goin with another intake would be to break out the degree wheel...find out where the cam REALLY is and go from there...not gonna get a sh!t load back but you can try to split the diff and see what happens.. or just ignore everything and go on with life...so you goin to 'cfest this year bro? just found out recently that I can! yippy...peace.
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
03-08-2018, 09:06 AM | #23 |
I have the sheets from all 3 times on the dyno.... seems like this thread had gotten off topic. I posted the recent and relevant info... thought others may find it interseting. I didn't realize it was going to be picked apart and criticized. My car, I'm happy with the results. Have a nice day...
03-08-2018, 09:06 AM | #24 |
4.56s in a 9" swap will fix it too lol
03-08-2018, 09:08 AM | #25 | |
03-08-2018, 09:24 AM | #26 | |
Drives: 2014 SS 1LE Join Date: Apr 2014
I then added twin turbos and left the same cam in took it to the same dyno / same tuner and made 830whp @ 14 lbs
03-08-2018, 09:56 AM | #27 | |
Now get it to the track. I bet your 50hp more hp 60 tq less h/c car will go slower than lazerlemons bolt on 5gen at his best vs as yours sets.. .....now that's what i call ignorant. The definition of ignorant is lacking of awareness or knowledge in general. You spent good money on this stuff. Do some research and make it work. You don't buy a intake like this and expect to run the engine in the basically stock operating range and expect great results. Really any h/c car worth the effort put in it should extend the operating range of the engine. |
03-08-2018, 10:07 AM | #28 | |
