07-25-2011, 04:37 PM | #1 |
Whipped
Computer dudes.. need help
I need a screen for my toshiba laptop. I watched a video on the install.. it is very simple.
What I am unsure of is where to get the screen Toshiba Satellite L300 Part No. PSLB8U-0LQ04H Serial # - 59367811Q Any help would be much appreciated.
07-25-2011, 04:39 PM | #2 |
Whipped
07-25-2011, 04:42 PM | #3 |
Drives: ( . )( . ) Join Date: Feb 2010
Youre best bet is to call the manufacturer and get the part number from them. or take the screen off and look for the part number somewhere.
Good luck.
07-25-2011, 05:10 PM | #4 |
Whipped
ok. i have the screen out.
IEC P/N: 6024B0033301 8 THE 6 COULD BE AN 8
07-25-2011, 06:33 PM | #5 |
does it have a barcode? on top of that pn?
07-25-2011, 07:21 PM | #6 |
from what i have looked at, either the one you posted (which is pretty inexpensive) or this one http://www.sparepartswarehouse.com/T...000133040.aspx should be fine
07-25-2011, 07:23 PM | #7 |
the 2 replacement P/N i found were:
V000100900 and V000133040 i didn't see anything about the number you gave us |
07-25-2011, 08:08 PM | #8 |
here are the national parts depot numbers for you
07-25-2011, 09:47 PM | #9 |
Whipped
Thanks for the info. I ordered the cheap one before looking back here. Is there a big difference ? Is the cheap one gonna be shit?
Most likely, that's why its cheap eh?
07-25-2011, 10:26 PM | #10 |
nah you should be fine, that replacement was the same resolution (1280x800) and size so it should fit just like the other ones, i just like to match p/n myself. i saw a good video on how to replace the screen, if you don't already have one.
07-26-2011, 10:35 AM | #11 |
Whipped
yeah, i seen a video on you tube... very easy replacement. Pop out and stick new one in... only two connectors. thanks a lot for the help all.
08-04-2011, 11:22 PM | #12 |
Whipped
go figure, I got the cheaper screen and for some reason it is barely bright enough to see..... BARELY see anything... It's going through a "system repair is checking your system for problems"
think the screen will get brighter when it's done?
08-04-2011, 11:35 PM | #13 |
Blessed
Drives: 2013 Sonic RS MT Join Date: Dec 2007
Sometimes they may need to break in bit if you cam barely see it. It may be bad normally they brighten up a bit but not quite that much. Check the connection to be sure they are tight.
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
08-08-2011, 10:31 AM | #14 |
Whipped
Hey jntarheels,
The part number on the back on my screen is V000120050 but when I plug my info into the website you gave me it gives me a different part number. Toshiba Satellite L300 (PSLB8U-0LQ04H)
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Fuse pull to reset computer | faninc | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 18 | 11-19-2010 06:36 AM |
Need help from Computer dudes here. . . | franknbeans | Off-topic Discussions | 86 | 09-14-2010 09:14 PM |
Camaro Computer | GearHeadPeter | 5th Gen Camaro SS LS LT General Discussions | 2 | 09-10-2010 03:22 PM |
OT - Need Computer Advice | Mblock66 | Off-topic Discussions | 29 | 08-20-2010 03:29 PM |
Camaro Computer hacks? | 2Muchmark | 5th Gen Camaro SS LS LT General Discussions | 17 | 02-06-2010 04:04 PM |
