Old 04-15-2019, 07:11 AM   #1
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
Active noise cancel aka Fake Exhaust
Is this right? I have tried searching the forum and generally out there, sorry if its been covered then show me the way.
Does the 2018 I4 M6 LS camaro have fake exhaust sound running through the stereo?
And how to disable that.
Thanks.
G.
wookwook is offline   Reply With Quote
Old 04-15-2019, 08:05 AM   #2
VinnAY
Drives: 18 1SS/1LE
Thanks.
G.
search for "sound tube"
Old 04-15-2019, 08:26 AM   #3
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Fake exhaust sounds thru the stereo - no. Induction sounds from the intake via a sound tube into the cabin - yes.
476 rwhp/440 rwtq (sold)
Old 04-15-2019, 09:19 AM   #4
Gutling
Drives: 2017 Chevrolet Camaro 2.0 LT
no sound tube on 4 cyls. they do have noise cancel, check your doors there will be little vents near the back.
As for canceling it, you can unplug them in the doors, or possibly snip a wire back at the amp. I am unsure on this, i have just seen it mentioned in a lot of stereo threads. If you install a subwoofer, there is constant bass if you still have the anc hooked up, I personally unplugged them from inside the doors so easy to replace if ever needed.
Gutling is offline   Reply With Quote
Old 04-15-2019, 11:53 AM   #5
wookwook
wookwook's Avatar
I noticed those little windows about shoulder height. I am planning on speaker upgrade, so I will definitely be in there. Will do an ear test next time out.
I should be able to finagle some kind of isolation test on the audio using my musician knowledge. Will update.
thanks keep them coming.
G.
