12-04-2019, 10:32 PM | #1 |
Drives: SS 6 speed of course Join Date: Jan 2016
Oldman supercharger cam sound
So I've designed my own "Oldman" supercharger cam... for all posers too old to race. It has a street friendly lift at .592 and mild spring pressure, pulls to 7200 RPM which is about right for a centri setup. Here is my near stock idle, stock exhaust with catted headers. Don't want to call any attention to my sleeper ridehttps://youtu.be/FYFU26L9gmI
12-04-2019, 10:37 PM | #2 |
Here is the forged bottom end before the Pray heads So I do like the sound of my "stock" exhaust.
12-05-2019, 01:18 AM | #3 |
Damn that sounds good! I want to be part of the under .600 “oldman cam” poser league!
12-05-2019, 06:11 AM | #4 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
Not bad for an old man! What kinda numbers is that monster laying down?
12-05-2019, 11:27 AM | #5 |
That sounds Awesome !!!
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11 RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453 SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/ |
12-05-2019, 12:15 PM | #6 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
I likey The other thing that tops my list besides a nice cam lobe is the smell of some fine race fuel Haha!
12-05-2019, 01:07 PM | #7 |
I'm have given up email tune because I can't hook the power to the ground sub 70 or 80 MPH with the oldsetup. I have to book a dyno tune and I'm on the fence if I do it in Austin, Houston or Corpus.
With the original Pray stage 1 cam .639 lobe zero overlap it would pull to 6800 rpm and be slightly off the power band 1st to 2nd. With this HUGE cam it pulls cleanly to 7200 RPM and there is no way to use wot on the upshifts 2nd or 3rd. 400 RPM on a centri comes out to about 1 PSI of boost through the entire applied power curve. Just some gross calculations, with the 4.0 pulley I should be moving enough air with a HP peak of 6800 RPM for say 800 to 850 engine HP. With the 3.65 pulleys I am getting close to max impeller RPM, the blower is listed at 1000 engine HP. When I chose the 11.5 forged pistons, I knew I would be octane limited to 800 ~ 850 engine HP, I would have gone 10.5 forged and a much heavier rod for HP above 850. https://tune2mod.com/products/wiseco...ecting-rod-kit Long story short, I have to edit my signature file again and put a 4.0 pulley. I'm on the fence on buying a C8 hence I'm spending less time and money on my Camaro.
