Old 12-12-2019, 11:15 AM   #15
Umbriel
Drives: 2016 Camaro SS
Originally Posted by Choda View Post
Im getting a msd 2 step for Christmas from the ol lady. I have an A8 and will be using the brake pedal as the power with a toggle to arm. I did this with my old turbo silverado and loved it.
splice into Brake pedal power - micro toggle switch - msd box.
when you want the 2 step, flip the little switch on and press the brake. when you are brake boosting sitting on the 2 step and then let off the brake, it will disengage the 2 step and you're off to the races. no need to use your feet and hands to launch correctly. I'll document it so you guys with autos can see how I do it. I never liked the idea of holding a button with your finger along with using booth feet when trying to launch a car.
Please do, I'll be doing one soon and like this idea better than the idea of having to hold a switch.
Umbriel is offline   Reply With Quote
Old 03-12-2020, 10:48 PM   #16
ChristianBTG
Drives: Chevrolet Camaro SS
2 step help ?
I got a 17 Camaro SS auto and I can’t get the 2 step to turn on the red light on the box only turns on when I turn off the car for a second then goes away? Do I need plug it in thru the brake or should I try a new switch? I feel like the switch I got isn’t a good one?
ChristianBTG is offline   Reply With Quote
Old 03-13-2020, 07:53 AM   #17
jorgesvlog
Drives: 2019 Chevrolet SS
I have the lingenfelter rpm limiter/ timing box and plan to use it more for timing retarding for the nitrous kit, but going to set the rpm limiter just for fun to make noise on a rocker switch that i can turn on or off. I believe most of these boxes require a positive 12v signal on the input wire to activate.
jorgesvlog is offline   Reply With Quote
Old 03-13-2020, 12:28 PM   #18
Choda
Drives: Turbo 6.2
I'm getting close to installing my 2 step. Converter is going in this weekend.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 04-07-2020, 10:21 AM   #19
Choda
Drives: Turbo 6.2
I installed the msd 2 step using the brake pedal in an Auto.
https://www.camaro6.com/forums/showt...=554303&page=6
