Old 05-30-2020, 07:26 PM   #1
DirtyBird
DirtyBird's Avatar
Drives: 2016 Black 2ss
For those using a Proclip
Does the phone holder need to be really tight to keep your phone from falling while driving, or can I leave it loose enough to easily slide the phone in and out? I have it tight enough right now that I need to use two hands to put it in and take it out.
DirtyBird is offline   Reply With Quote
Old 05-30-2020, 08:38 PM   #2
Blue_6.2
Blue_6.2's Avatar
Drives: 2019 1SS Convertible
That would be too tight. Mine is adjusted so that the phone can easily settle into proper position under its own weight.
Blue_6.2 is offline   Reply With Quote
Old 05-30-2020, 08:43 PM   #3
Paintslinger16
Two Lane Blacktop
Paintslinger16's Avatar
Drives: '18 Camaro 2SS
Just needs some slight tension
Paintslinger16 is offline   Reply With Quote
Old 05-30-2020, 10:03 PM   #4
Walkure
Walkure's Avatar
Drives: '17 ZL1 A10 Vert
I have the dash mount. It’s loose enough so that the phone slides in and out pretty easily. The only way the phone will ever “fall” out is if my car is upside down.
You just need to adjust it a bit.
Walkure is offline   Reply With Quote
Old 05-31-2020, 01:25 AM   #5
Tyestick
Tyestick's Avatar
Drives: 19’ Camaro SS 1LE
You’ve got it too tight. You just need to fine tune it, to make sure it’s not too loose.
2019 Camaro SS 1LE
Tyestick is offline   Reply With Quote
Old 05-31-2020, 08:23 PM   #6
DirtyBird
DirtyBird's Avatar
Thanks for the suggestions!
Old 06-01-2020, 04:54 PM   #7
crosive
Drives: 18 zl1
can you share some pics of this one? I was on the fence about it, but ultimately decided for the other one due to possible permanent marking the dash.
crosive is offline   Reply With Quote
Old 06-03-2020, 09:11 PM   #8
AndyDove21
AndyDove21's Avatar
Drives: 2020 Camaro 2SS Rally Green
I have the exact same concern. The destructions suggest levering open a join in the dash to insert the ProClip. Does that leave a mark?
AndyDove21 is offline   Reply With Quote
Old 06-04-2020, 06:45 AM   #9
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
My concern is more along the lines of once you mess with the factory seam on any of these dash parts you always seem to develop a squeak. You are spreading apart that seam to insert that clip (all be it just a little bit) but has anyone developed a squeak from doing so?
jamala00 is offline   Reply With Quote
Old 06-04-2020, 09:09 AM   #10
Walkure
Walkure's Avatar
This is a pic looking straight down from above so you can see the seam where the mount attaches.
I've had it installed for over two years. No rattles or squeaks.
Old 06-04-2020, 01:44 PM   #11
Tyestick
Tyestick's Avatar
I’ve been think about getting that mount. I have the proclip that mounts on the bolster.
Your mount, does it interfere with your turn signal stalk?
2019 Camaro SS 1LE
Old 06-04-2020, 05:53 PM   #12
Walkure
Walkure's Avatar
It’s close, but no. It doesn’t get in the way of the turn signal stalk.
Sorry - pics got rotated posting from my phone.
Old 06-04-2020, 10:56 PM   #13
Tyestick
Tyestick's Avatar
Thanks for the pictures. 👍
Nice to see a close up visual of that mount on the dash.
2019 Camaro SS 1LE
Old 06-05-2020, 06:25 AM   #14
jamala00
jamala00's Avatar
+1... Thanks for the pictures... Like Tyestick said, it's nice to see pics of it on the dash...
