06-02-2020, 09:48 AM | #15 |
Drives: 2016 Camaro 2SS Bright Yellow Join Date: Apr 2016
Yes, the wheel straps on the front of the trailer are all I used. They kept the car firmly in place. I didn't have any worries about using them alone, for the front. I ended up twisting up the safety chains to keep them from dragging and swinging around. I would have to look under the rear of my car again to see exactly where I wrapped the straps. I believe I went around the rear swingarms. As a stated by another member, the rear straps just keep the car from bouncing around and add some additional stability. Just need to avoid wrapping the straps around any brake lines or electrical connections/wires. I ended up buying the tie down brackets from a vendor at CamaroFest to make things easier in the future.
2016 2SS, M6, NPP, MRC, Magnuson 2300,
JRE Rough Idle Cam, 95mm TB, Dynatech headers, Cat delete, Borla ATAK |
06-02-2020, 09:51 AM | #16 |
Hot Camaro
What about using an 8 point system on the U-Haul trailer in addition to the wheel straps for the front that are already there?
06-02-2020, 02:42 PM | #17 |
That is an option to, I haven't used those harnesses when hauling my car, but it would work to. Honestly once you tighten the over the tire straps/web around the front tires, you will see how well the car is held to the trailer. I covered 1600 miles over some rough highways and had zero issues.
06-02-2020, 02:43 PM | #18 | |
06-02-2020, 08:12 PM | #19 |
Just in case someone reads this thread down the road: attaching plates from another vehicle is a felony in Massachusetts, FYI. Definitely do not want to do that.
To the OP: do you know anyone with a good quality trailer you can borrow? Just seems like the U-Haul ones are a recipe for trouble IMO.
06-02-2020, 08:45 PM | #20 | |
I’m not making light of anyone’s concerns. https://www.google.com/amp/s/www.aut...79906656%3famp |
06-02-2020, 09:12 PM | #21 | |
*PIMP*
Drives: 2018 2SS Join Date: Nov 2017
For about $400 you can have it delivered VIA truck. If you can't afford that, then buy a car in NC and be done. You're making this a bigger deal than it needs to be. |
06-02-2020, 09:18 PM | #22 | |
06-02-2020, 09:22 PM | #23 |
Hot Camaro
I stopped at a U-Haul location tonight and measured two trailers that they had on the lot. Both could accommodate a maximum width for the wheels of 79.5 inches while the specs on the car state a maximum width of 74.7 inches. So, while it isn't a lot of space on each side, it's completely doable.
For reference, the iteration I spoke with started that there are now three different car trailers, ALL of which are the gray galvanized steel. The GTWR of each is 6k, 7k, and 7.5k. The 7.5k version appears to be the newest version, but also has the coupler I would trust the least. So, I'm going to ask for the 7k model (this has the coupler that you screw down the clamp). The width of the track is 19" and the space from the very front edge to the bar that the straps are permanently attached to is about 19" as well (it's 20" on the 7.5k trailer. I will be cutting 2x8's at 19", stacking two, and beveling the leading edge of the top one. A second 19" board will sit ahead of the bar to help raise the front as the wheel approaches the stacked boards. I'm going to get some additional wood or together into "ramps" to put under the rear wheels of the truck to help with loading angle. I'm going to leave the rear of the car "loose" - there isn't a good way to lash it down with straps and there's no way I'm putting that chain anywhere near the underside of the car. It's all smooth highway to get home, and I will be well under the speed limit. |
06-02-2020, 09:25 PM | #24 | |
Hot Camaro
Why would I buy a car in NC? As, as stated, this specific car is basically the only one of its kind left for sale. So, nothing about your response is accurate or helpful |
06-02-2020, 09:43 PM | #25 | |
06-02-2020, 09:44 PM | #26 |
Hot Camaro
Trailer will total about $75 with taxes. Tolls will increase by about $10. Extra gas... Maybe another $30. No insurance additions required.
06-02-2020, 10:20 PM | #27 |
I remember spending a lot of time and sometimes wasted effort, either because I had little $, or I just wanted to do something my way ( sometimes both). My guess is you’ll spend more $ on gas and worry about the ass end of the car not being secured (I know I would), hope to hell the wood you brought will do what you intended etc. Anyway you slice it, if you move forward with this plan, you’ll have to post up pics of the loading process / car.
06-03-2020, 06:49 AM | #28 | |
Hot Camaro
Yes, I won't know whether any of it will work until I try it myself, but I'm comfortable with that part of the risk because I have found so much really useful information from other threads in this forum about this very topic. I plan to get some pics and maybe even video of the loading and unloading. |
