10-28-2020, 09:06 PM | #1 |
Drives: 2018 A10 ZL1 Join Date: Oct 2020
Magnuson2650R Pulley/belt questions
I have a magi2650 coming up for my A10 Zl1 i also have intake/headers and meth injection on my car with a Jms volt booster, 103mm throttle i am thinking of going up to 16 psi with a 80mm griptec upper pulley and a stock lower, i am wondering how much power will i be making with these mods, i also am wondering what is the belt size for a 80mm 8rib upper and the standard lower pulley.
10-28-2020, 09:17 PM | #2 |
Drives: 2019 ZL1 Join Date: Mar 2019
80mm pulley will increase boost 3-4psi. You’ll be way over 16. More like 18. I wouldn’t put that pulley size on with just meth. You don’t have a cam?
I have the 90mm and I’m just right under 15 or 15 based on air conditions. |
10-28-2020, 09:21 PM | #3 |
No, i don’t have a cam on, i talked to magnuson department and they told me to go with a 80mm for 16-15 psi and that the standard 90mm will give me 13-14 psi only, what are your exact mods/numbers?
10-28-2020, 09:26 PM | #4 |
Magnuson 2650 90mm, kooks 2” headers, borla 3” cat back, nw 103 tb, mm catch can, NO CAM, NO METH, right at 700rwhp on a dyno jet and I’m at fueling limits.
10-28-2020, 09:34 PM | #5 |
Based on your info, i should be able to push 15-16 with a 90mm.. must’ve been a bad call from the salesman, still i am trying to push 780-800 whp but i dont think its possible with my current mods.
10-28-2020, 09:46 PM | #6 |
Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
My car saw 15-16psi with the 90mm pulley with the 2650R. An 80mm pulley is going to be 18+, the blower will move the air easily...going to run out of fuel though.
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
10-28-2020, 09:46 PM | #7 | |
What’s it hitting now on the dyno and what boost? Adding a cam will get you to that goal. |
10-28-2020, 09:51 PM | #8 |
I guess i’ll have to use the standard 90mm for now until i get some more supporting mods on, still didn’t run it on the dyno waiting for my turn within a few days, i will hit you up with any updates.
10-28-2020, 09:57 PM | #9 |
Yeah you need to get it on the dyno and tuned and see where your fueling is before you even think about adding more boost.
10-28-2020, 11:00 PM | #10 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
10-29-2020, 07:44 AM | #11 |
I'm still tuning my old Camaro for the new owner. We were on the dyno a while back and with the 80mm pulley, stock lower we were 14 lbs of boost, it has cam, headers and no cats. However if your on stock exhaust, no cam I think you'll see about 16-18 on the 80mm and probably about 12-13 on the 90. Every 5mm is about 1.5 to 2 psi of boost. Remember some will depend on your elevation, I don't know what that is in Kuwait. Good luck and have fun with it.
10-29-2020, 07:58 AM | #12 | |
Petro-sexual
When I was tuning in about 90* weather, I was seeing about 14-15-psi (mods in signature). As soon as temps' got into the lower 60s, I was seeing a couple pounds more, with no other mechanical changes. I'm at sea level, and can get pretty good DA around here.
10-29-2020, 09:02 AM | #13 |
Agree...DA plays a huge factor in the amount of boost made. I see a 3 psi difference from 90 degree weather vs 50 degree weather.
2016 NFG 1SS A8
10-29-2020, 10:03 AM | #14 |
Drives: 2018 zl1 10 speed Join Date: Oct 2018
I had exact set up with just 80mm pulley and stock lower we were seing over 18 19lbs and was too much boost for the car . We put cam 38% lobe and 85mm pulley now at 15 lbs
Tags |
zl1.magnuson2650.pulley.belt |
