02-27-2015, 02:38 PM | #1 |
Drives: 2019 Grand Sport Join Date: Jan 2014
Z06 Reproduction Rims and Tires
Please help!!!
I've found a great deal on C6 replica rims with drag radials. Am I correct in assuming that all C6 Z06 wheels fit the 5th gen Camaro SS??? The seller does not know the offset. Fronts are 18x9.5 with 255/40/18 tires and rears are 18x10.5 with 315/40/18 Nitto drag radial. |
02-27-2015, 02:57 PM | #2 |
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
02-27-2015, 05:53 PM | #3 |
"Cam Only"
Those rears need to be +53 offset to work without a spacer.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno) |
03-05-2015, 09:47 AM | #4 |
Thanks for the help. Where Is the best place to get wheel spacers and will the fronts fit without spacers?
03-05-2015, 11:24 AM | #5 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
My experience is that 18x9.5, +40mm offset will need grinding on one spot of the front and a 5mm spacer with 265/50/18 tires. Might not need spacer with those tires, don't know, but the rim above will requiring of this "knuckle."
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
03-13-2015, 02:46 PM | #6 |
The rears fit however the fronts don't come close. Is there a company that can modify the fronts to skinny's that would possibly fit? Preferably in Florida.
