10-25-2014, 10:46 PM | #1 |
Master Amateur Mechanic
Drives: Victory Red 2011 2SS/RS Join Date: Jan 2013
Picked up Injectors, do these look real?
Just wanted to let everyone know if you offer 500 they counter offer 594.79 for a set of 8 id850 injectors. Just picked up my set. Through paypal and returns accepted!
http://pages.ebay.com/link/?nav=item...d=390614671425 UPDATE: JUST CAME IN. Do these look real or like fakes? Here are the injectors, got them today. Do they look right? If not looks like I'll be sending them back for a full refund! |
10-26-2014, 08:21 AM | #2 |
Drives: 2006 Z06 Join Date: Oct 2010
All the ID injectors I've got come in an ID box, with the paperwork/test results.
Nick
Corvette Z06 -1200ish rwhp |
10-26-2014, 08:48 AM | #3 |
Drives: it changes Join Date: Nov 2010
Don't ID usually grind off any of the original Bosch etc part numbers ?
10-26-2014, 09:18 AM | #4 |
Yep, and etch their serial numbers on them.
I would say those are just bosch 80lb injectors.
Nick
10-26-2014, 09:53 AM | #5 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
Agree. Never seen ID's not coming in the box, with papers. Houston, I think we have a problem.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
10-26-2014, 10:37 AM | #6 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I'm a frequenter of ebay myself and have gotten a lot of great deals, so when I was looking for injectors for my truck, I checked them out. After seeing a lot of really cheap high flow injectors, I started Googling because something did not seem right. Then I learned that there are companies who enlarge the holes on the bottom of the injectors to increase the flow rates and the rates between their injectors are all over the board.
I still got the injectors off eBay, but they were unused pink injectors from a Magnuson supercharger kit which the guy did not need as he went bigger right off the bat.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
10-28-2014, 10:33 PM | #7 |
Drives: 2010 2SS Join Date: Sep 2012
They are definitely something other than id injectors. If you want good injectors for that price check out FIC injectors. Same as i.d.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
10-29-2014, 12:12 AM | #8 |
Syntax Error
10-29-2014, 04:51 PM | #9 |
Drives: 2013 ZL1 Join Date: Aug 2014
If they aren't laser etched with the injector dynamics logo they are something else
10-30-2014, 08:17 AM | #10 |
Dyno Show Queen LOL
How do we know they are not made by IDS and rebranded as a generic or other brand? Happens all the time! Batteries, Rc motors, Cereals, oils, Crankshafts.. I'd call IDs and find out if they sale to other companies? (sometimes the real brand will have higher standards but not always the case) Usually the company that resales is not supposed to say the mfg name, they keep it secret so there parts can be priced different and not have to sell at a set price.
10-30-2014, 08:54 AM | #11 |
Because ID doesn't do that.
Nick
10-30-2014, 09:04 AM | #12 |
Drives: '11 Camaro Supercharged Convertible Join Date: May 2014
Those injectors that you have there are FAST 65lb injector. Just google the part number on there and it'll show up. The fist number looks off, but if you have a barcode scanner on your phone, it'll read 80527 from the QR code below the part number. I would return them and get your money back for receiving a fraudulent item. Then take that money and get a real set of ID, Bosch, or FIC injectors.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
