08-16-2020, 08:33 AM | #1 |
'20 A10 LT4 redline and rev limit (?)
My 10-sp is short shifting at 5500-6000 rpm in both track and sport modes (I'll try it this morning in tour) on the 1/2 shift and sometimes 2/3 shift.
Maximum LT4 HP is at 6400 rpm so I naturally assume a good shift point is around 6600 rpm. Who else here has had this short shift/rev limit issue and how did you solve it?
'20 ZL1 1LE A10,
08-16-2020, 09:12 AM | #2 |
Drives: 19 Camaro SS 1LE, 03 Ford Lightning Join Date: Nov 2019
How many miles are on the car? I don't think GM has any kind of HP or RPM limiters built into the Camaros, but they do on the C8's. I think you have to hit like 500 miles to get the max HP from them or something like that.
08-16-2020, 09:13 AM | #3 |
Short shifting the 1-2 and a bit on the 2-3 usually makes you faster, especially cars with fat torque curves and aggressive gearing. They are set like that from the factory
08-16-2020, 09:36 AM | #4 |
1800 miles
My experience is that shifting at or just beyond max hp is best.
'20 ZL1 1LE A10,
08-16-2020, 09:38 AM | #5 |
JSH, I wonder if the tune you have might be causing the situation you are experiencing since your ZL1 is modded.
08-16-2020, 09:44 AM | #6 |
Probably because your trans tune is stock but your engine tune is modified. I don't think you can tune the TCM(I know for fact on the SS not sure on the ZL1) in the 2020+ since GM switched to the T93 controller. So the only thing you can do is manually shift it if you want to shift higher.
2016 NFG 1SS A8
08-16-2020, 09:45 AM | #7 |
Might be, so I asked them via email last night.
'20 ZL1 1LE A10,
