02-07-2020, 09:32 AM | #1 |
Drives: 2010 Chevrolet Camaro 2SS RS Join Date: Jan 2020
Powder coating
Wanting to go darker on my rims without spending $1500+ on a new set, so trying to find out how much it generally costs to powder coat my 20’s. Anyone have any idea?
02-07-2020, 09:37 AM | #2 |
Not sure why photo Is posting upside down... tried multiple times
02-07-2020, 09:49 AM | #3 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Single color usually $400-$600 is what they charge around central Ohio.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
02-07-2020, 10:31 AM | #4 |
Here in Fl my shops charges 104 per wheel for 20's.. Any color..
02-07-2020, 10:40 AM | #5 |
Drives: 2015 Z/22 Join Date: Aug 2015
I painted mine with an enamel spray paint (see last post here https://www.camaro5.com/forums/showt...7787&page=1505) and thought it came out pretty good. Since then there's a bit of road rash (sand blasting while driving) and the odd minor scratch but I had the same kind of damage on the factory finish too. Was about $200 total (Canadian, so probably like $100 for anyone in the States), all cleaning and prep materials and paint.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
02-07-2020, 04:11 PM | #6 |
02-07-2020, 10:24 PM | #7 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i have a old friend in savannah that works in the paint department at gulfstream and he powder coats on the side he will probably do all 4 for 400.
02-13-2020, 04:29 PM | #8 |
Sorry, just saw this. The shop is in Palm Bay and it is Elite Powder Coating. Talk to Kevin and tell him Wayne sent ya..
