01-23-2020, 09:18 AM | #1 |
Drives: 2010 Chevrolet Camaro 2SS RS Join Date: Jan 2020
Water pump replacement
So just took my new ride (2010 2SS) in for an oil change. My water pump has a knock in it and is supposedly on its way out. What would be a reasonable price to pay to have that replaced? And should I just replace with a standard one or is there a better one I should install?
01-23-2020, 09:50 AM | #2 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
https://repairpal.com/estimator/chev...placement-cost
Your first water pump lasted 10 years. It is a wearable part. Replace it with OE. |
01-23-2020, 12:10 PM | #3 | |
Drives: 15 Camaro SS Join Date: Oct 2018
01-23-2020, 12:11 PM | #4 |
Instagram: Sangstah
It's very very simple to do yourself. It took me maybe an hour in the garage, its just a little messy with dumping the coolant. Youtube video tutorial for the win!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
01-26-2020, 09:45 AM | #5 | |
+1. It is a very easy job. Grab a new one from the dealer and toss it in. If they try charging you an arm and a leg I think we can get one for $250 shipped. Watch out for knock offs online |
02-29-2020, 08:47 AM | #6 |
oe on amazon matches rockauto part number. $130. Dealer 349, Rockauto 169.00 plus ship.
Update...Build in process, Forged Rods, Pistons and rings, Johnson Lifters, NOVI1500 ECS SC, 13lb boost or more, LS3 Conversion 114/228/241 COMP CAM, Frostbite 4 row Aluminum radiator, 6L80 built, Circle D 6L80 PRO SERIES MULTI 258MM 2D, Stock 3.45 gears, 1-7/8 American Racing Headers w/HF cat, X-Pipe, Lingenfelter dual fuel pump, E-85 flex sensor, ATI super damper pulley, Ported TB, 160 therm, Trans cooler, Pedder's sways/end links/sub frame bushings, BMR trailing arms & toe rods, Coil overs. HP/TQ pending
02-29-2020, 10:37 AM | #7 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
It is a real simple DIY job. Go OEM and change the T stat and flush the system ,use Dexcool and distilled water. Check hoses and belts and replace as needed.
OLD GUY FLYING FAST AND LOW
02-29-2020, 03:13 PM | #8 |
I love RockAuto. Not only do they have great prices but the entire site can be used as an amazing cross reference tool for part numbers.
