05-16-2018, 01:27 PM | #897 | |
Drives: 21 Bronco Join Date: Jun 2012
Well you discounted all the performance shop runs that ran low 12's saying they must have done stuff to them(which is an asinine thing to say why would a performance shop want a stock car to be that fast? then their tuning and packages don't look as impressive if anything they would have sandbagged them). you discounted the early owners runs, you still seem to discount them, you discounted the evan smith run and you said the Cars.com run wasn't legit. People kept bringing you examples of the car doing things and none were good enough for you to believe. You kept being skeptical that there was trickery done. Or at least that's the way the majority of your posts read. So just wanted to bring it to the forefront since you love you some magazine times. C/D has the A10GT faster than the A8 SS, and faster than the 350. Both things you said wouldn't happen and as far as it taking people time to get it, why do you give the Hellcat and Demon the benefit of the doubt of people need time but the Mustang has to do it off the assembly line? |
05-16-2018, 01:29 PM | #898 | |
Drives: HB 2SS Join Date: Apr 2017
I believe the euro tax plays a role and probably EPA. Going above 5.0 will mean a higher tax in the EU market. The next step would be to reduce the displacement and introduce F/I into the mix (C63 AMG) OR a hybrid system alternatively (Think NSX). If you want to see how much can be done with a 5.0 V8 DOHC just look at Lexus. Their V8 has been ahead of Fords for a while now. Motor to motor they are the current benchmark. Based on this logic they can still squeeze out another 10HP out of the coyote N/A. |
05-16-2018, 01:35 PM | #899 | |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
And it still failed to win in the 1/4 mile again proving my point. |
05-16-2018, 01:35 PM | #900 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
Given the current bore spacing and deck height, the max they could produce in a V8 format (the line can make V6's, V8's, or even V10's) would be in the 5.2 - 5.4 range IIRC. Any bigger, and they would have to go to a V10. I believe that this is the reason Dodge went V10 on the viper. So, if ford wanted to go to a 6.0L V8 engine, they would need to upgrade the plant to accommodate an engine block with a wider bore spacing and greater deck height. That would be a huge investment, and it would have to tie in with a whole family of motors that would share the same bore spacing and deck height. They could make a 6.0+ Liter V10, but it would be a significantly longer engine (and not fit in a Mustang). And even if they upgraded the plant that acomodated the wider bore spacing and deck height needed to go for a 6.0+ Liter V8 engine, if they went DOHC, it wouldn't fit in the Mustang. A OHV engine of that size would fit (like the LT1), but going that big with displacement and DOHC would probably be just too big to fit the current S550 platform. Hope this helps! Last edited by whiteboyblues2001; 05-16-2018 at 02:00 PM. |
05-16-2018, 02:34 PM | #901 | |
Drives: 2018 GT PP1 A10 Join Date: Mar 2008
per Car and Driver, 1/4 mile: 2016 SS Auto: 12.3@116 2015 Challenger 392 Auto: 12.6@114 2018 GT Auto: 12.1@120 At this point, its retarded to argue that the Camaro is faster. |
05-16-2018, 02:39 PM | #902 | |
Drives: E92 BMW M3 Join Date: Oct 2012
Congrats on the Mustang man!! You're right, that active exhaust sounds AMAZING!! I see a GT350 a couple times a week here in downtown Houston, not the same one, and the few GTs with active exhaust I have heard sounded almost as good!! That's huge, because that Voodoo is intoxicating.
J-Rod Built and Matt@FSP Tuned |
05-16-2018, 02:45 PM | #903 |
Drives: 2017 Camaro Join Date: Mar 2018
Don't even bother trying to argue with him. He will argue with a brick wall even though the proof is right in front of him. It's always a ringer/conspiracy theory and unless he personally picks out the cars, the track, the drivers, the day, and races and the results are what he wants. Just ignore him, he's an idiot.
05-16-2018, 02:55 PM | #904 | |
Drives: 2019 GT350 Join Date: Jan 2011
C&D 12.10 @ 120-mph Cars.com 11.90s @ 119-mph Hot Rod/MMFF 11.80s at 119.5 mph The fastest reviewed time for the Camaro is 12:20s so the discussion is now over as to which car is faster at the strip, or until the 19 A10 SS hits the streets?
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot |
05-16-2018, 03:18 PM | #905 | |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
But you certainly are exaggerating. For what reason and what you think you have to prove is unknown to me. I said from the start that I was basing my times off 3rd party unbiased independent testing. I never said that anyone didn't run any specific time although I did express my doubts and did make justifiable remarks that some of the runs could have been with modded cars. For the record, even on Evan's YT video of his run one of his long time followers also thought Evans removed the sway bar and did other modifications to the car. And we certainly have seen several incidents of Mustangs being modded and certain mods not being listed or mentioned or counted. So I never said anything that wasn't justified. I discounted the early owner runs as being official. I have said that time and time again and not one of you Mustang fanboys, to this day, comprehends that. I clearly said, and I'll go back and find the post, that if you count the YT videos and owner runs, then you cannot compare it to Camaro magazine times...which is exactly what SS Friendly and his posse were trying to do. I said that the only way to use those times fairly would be in comparison to Camaro owner YT videos, runs, etc. Now answer this, is that not a fair and reasonable statement? And even then I said that owner runs are not counted as official. I said clearly from the start that the Camaro has done high 11s but none of us here consider it a high 11 sec car. Others have backed up that statement. I said that the Camaro is officially a low to mid 12 sec car. But you won't call me out on that or accuse me of discounting Camaro times will you? Because you're focused only on the things I've said about the Mustang even when I said the same exact thing about the Camaro. Hypocrite much?? And I wasn't the only one who expressed doubts. There were several others. And rightfully so. If I had a dime for every car owner who told me they had an 11 or 10 sec car and were flat out lying then I'd be wealthy. Anyone can post up a video and run their car to the 11s and say it was stock. I'm supposed to cheer and hoot and holler every time some lying asshole wants to lie to impress someone. GTFO here. And for the record, I made those same comments about Camaro owners. And I don't "love" magazine times. You can try to be a smartass all you want. But without official testing of these cars, then who's to say what car is what and does what? Are you telling me that you'd be gullible enough to believe everyone who tells you what their car can run? Please, I'm all ears, you tell me the best way to officially say what these cars can or can't do. Because if that's the case, then my ZL1 runs 9s all day while getting 50 MPGs city. You can huff and puff all you want. I made my comments way back when. I said way back when that I would stand by everything I said. And I stand by my comments. The Mustang for the past 5 months has not done a low 12 sec in the fashion I described. And you yourself sat up here and admitted that I was right at the time. And I'll tell you this much...put it on the line with the SS and I'm still on the Camaro's side for taking the victory. And for the record...even RP said the Camaro was still the faster of the two cars. So you can act all arrogant all of a sudden...maybe you were saving all this all along. Doesn't matter to me one bit. If you think any of this changes my opinion of the Mustang then you're sadly mistaken. If anything, at best, it's a driver's race in a straight line, can't keep up at all in cornering, costs more, and has to be optioned to the stars just to do that. |
05-16-2018, 03:26 PM | #906 | |
It hasn’t gone faster with private owners either Car and driver 12.3@118 m6 ss vs 12.6@115 m6 gt. If you want to compare different days. Not really saying the SS is faster. If you get a gt a10 with drag mode I think it may be faster stock for stock. It’s just not by as much as you think. I’m nearly as fast as steeda shop built a10 gt with more mods than me and race fuel. Keep arguing tenths in stock cars if it makes you feel better. You will still be far from immune to a Camaro at the strip. They are close competitors |
05-16-2018, 03:28 PM | #907 |
Exactly. Up until now they have tried every angle to give the Mustang a shallow win. Even a test which played to the Mustang's strengths and at that on a dirt road. And even then it was a squeak win. The SS came out in 16 and guys took it to track days and ran high 11s. The GT comes out, is optioned a specific way, is given directly to vendors and mags who then made attempts on track rentals in the dead of Winter and only then were able to run what the SS has been running for 3 years. LOL!! And now 5 months later another specifically optioned GT manages to do what we've been doing all along and at best is within a driver's race. So what exactly are any of us supposed to be impressed with? That it took Ford 3 years and some extensive upgrades and a price hike and a special drag mode to match the unchanged since 2016 SS that you can just buy as optioned? Ok. Wow.
05-16-2018, 03:51 PM | #908 | ||
Example Quote:
It's not our fault that none of the magazines tested the A10 car till this month. And yes I did say you were right when stuff popped up that you called. And here I am now calling you out on things you got wrong lol. Especially the GT350 thing, I remember you be quite adamant that the GT would not be faster in the 1/4 because it was just a GT lol.
05-16-2018, 04:42 PM | #909 |
Drives: 2013 GB GT Join Date: Mar 2016
people really get worked up over a couple .1's on a drag strip or road course.
these cars are so close in performance that if this was an actual Dick measuring contest you would just call it even rather than actually measuring. |
05-16-2018, 04:47 PM | #910 |
It’s a delusional excuse to think that a same day comparison is the only valid argument.
It always amazes me how people in general can have such a lack of introspection in thought process combined with massive hypocrisy. M6g mirrored this place and more two years ago. And to think a same day comparison is not important is just plain stupid. |
