11-19-2020, 08:36 AM | #1 |
Drives: 2018 Camaro SS/1LE Join Date: Jan 2018
305/35/20?
Anybody with a 1LE try running the M/T’s street s/s 305/35/20? Just curious if they will fit without rubbing and how they do on the m6... or any other suggestions for a good grip tire for drag (yes, I drag my 1le)... also want to be able to keep my nitto g2’s on the front.. just want a good tire I can swap on/off the rim only for straight line, won’t be daily driving and will switch back to my rear g2’s for dd
2018 SS/1LE... summit white.. E85 ,Ported LT2 IM, Roto Fab, soler performance ported throttle body, secondary delete, mbrp axle back, tuned by CCNC
11-19-2020, 10:40 AM | #2 |
You will need to relocate the wiring harness in the driver side rear fender well. Other then that they will work better at the track then any other tire that size.
2016 NFG 1SS A8
11-19-2020, 12:18 PM | #3 | |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
11-19-2020, 03:02 PM | #4 |
If I did the 555r I could use my regular 30 series. I keep seeing mixed reviews on those tho.. the m/t don’t have a 30 series, just the 35.. so I was just wondering if the 35 would even work without rubbing (“after relocating harness“)... I even looked at running the r888r on the rear but was told it wouldn’t be stable if I kept my g2’s on the front with them
11-22-2020, 10:51 AM | #5 |
I had the original 305/35/20 555r when I was bolt-on only and could pull 3.4 0-60's on the street but I am A8. They required relocating the harness.
I think a 305/30/30 555r2 would be a better choice for your car from a gearing standpoint with a M6 but the 305/35 will likely hook off the line the best.
2016 NFG 1SS A8
