06-24-2014, 02:20 PM | #85 | |
Drives: 21 Bronco Join Date: Jun 2012
06-24-2014, 02:36 PM | #86 |
Drives: 2012 Ford Focus Join Date: Jan 2014
Compare the CTS Vsport to the SS sedan. Pretty much the exact dimensions. Alpha platform vs Zeta. Weights are nearly identical.
http://media.caranddriver.com/files/...twin-turbo.pdf http://www.motortrend.com/roadtests/...ss_first_test/ Granted I don't know the weights of the drive train combos, but i figured they were close. |
06-24-2014, 02:37 PM | #87 | ||
06-24-2014, 02:38 PM | #88 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
I have had a hard time finding good numbers on the weight of the LT-1. However, what I have found suggest it doesn't weigh a whole lot more than the LFX V6 and a little less than the LS3. However, as someone pointed out before, that isn't where all the weight comes from. The V8s tend to be paired with beefier transmissions, brakes and differentials. I don't think the new 8 speed auto or 7 speed manuals will be lighter than the 6 speeds we have now. I HOPE I AM WRONG though.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
06-24-2014, 03:45 PM | #89 | |
Drives: 2010 ZR1 "Satan" Join Date: Nov 2013
This is the classic example of Area Under The Curve. The performance should be very close. 107.6 mph traps for the SS 111 mph traps for the CTS Vsport That's a pretty big difference, and would normally mean ~40HP difference, not the 5 HP / 15 FT-LB shown on the brochure. The V6 Turbo has more average HP. Effectively, like a NA V8 that reports 455+ HP (LT1). This is probably why the V6 Turbo is probably not going into the next Camaro. The performance will match the LT1, but without the V8 sound.
2002 Z06 "Blue Meanie" 11.36 ET
2003 Z06 in progress 2009 CTS-V "Spooky" 12.36 ET, bone stock at 1600 mi. Rainy day in Sacramento. Sadness. 2010 ZR1 "Satan" no times yet. 2013 Volt SCCA Solo2 #771 HS3. And a bunch of Duramaxes. |
06-24-2014, 03:47 PM | #90 | |
06-24-2014, 03:51 PM | #91 |
Yes, but the weight difference of things like sway bars, struts, control arms are pretty small. Although, lots of small differences can add up.
06-24-2014, 03:53 PM | #92 |
Torque is what requires bigger axles, gears, motor mounts, driveshafts, etc.
I doubt the fully dressed V6 Turbo weighs much different than the LT1. The intercooler and turbos alone are perhaps 50lb.
06-24-2014, 03:54 PM | #93 |
Track > 1/4 Mile
LESS than the LS3? I'm shocked.
06-24-2014, 03:56 PM | #94 |
That's a lot of guess work on my part. I've done a lot of google searches trying to find something authoritative about the LT-1 weight. All I've seen is estimates and those are all over the place. DI adds some weight, but it looks like GM tried to shave weight everywhere they could.
06-24-2014, 04:00 PM | #95 | |
Drives: some to distraction Join Date: Sep 2011
You are absolutely correct in stating that beefed-up other driveline components add further weight. As usual. |
06-24-2014, 04:01 PM | #96 |
Do you have some links? Like I said, I have't found anything authoritative.
06-24-2014, 04:05 PM | #97 |
06-24-2014, 05:53 PM | #98 | |
http://www.topspeed.com/cars/car-new...-ar136830.html |
