05-11-2016, 08:15 AM | #1 | |
General Motors Aficionado
Drives: 2023 GMC Canyon, 2020 Colorado Join Date: Aug 2008
ZL1's 10 Speed Hydra-Matic Automatic Transmission Faster Than DCT / PDK
Camaro ZL1’s Lightning-Fast Transmission is a Perfect 10
New 10-speed auto offers quicker shifts than DCT, sets new performance standards General Motors May 11, 2016 DETROIT – With faster upshifts than a dual-clutch transmission and a wider overall gear ratio spread to optimize performance and efficiency, the all-new available Hydra-Matic 10-speed automatic transmission sets a new performance standard in the 2017 Camaro ZL1 – and raises the bar for the segment. The ZL1 is expected to be the first volume production car to offer a 10-speed automatic. It builds on the established legacy of Hydra-Matic eight-speed transmission family offered on other Gen Six Camaro models, to deliver higher thresholds of capability, refinement and efficiency. “There is simply nothing like the experience offered with the new 10-speed automatic in the Camaro ZL1,” said Aaron Link, ZL1 lead development engineer. “It delivers nearly instantaneous, lightning-fast shifts that alter your perception of what an automatic transmission can offer in a high-performance vehicle – whether you’re on the street, drag strip or road course.” The greater overall performance and efficiency are due primarily to the 10-speed’s wider 7.39 overall gear ratio spread, which enhances off-the-line performance with an aggressive first gear ratio of 4.70. Smaller steps between the gears also help the engine maintain the optimal speed for maximum power at almost all vehicle speeds, especially when exiting a corner on a track. “The gear ratios are so tightly spaced that the transmission is in the right gear and the engine is at the best rpm for transitions from corners to straights,” said Link. “And with the power from the ZL1’s supercharged LT4 engine, the force you feel in your seat as you accelerate out of a turn will put a grin on your face every time.” Chevrolet testing has shown the ZL1 with the available 10-speed has faster shift times than the Porsche PDK dual-clutch transmission. In fact, the 1-2 upshift is 36-percent quicker than the PDK, while the 2-3 and 3-4 upshifts are 27-percent and 26-percent quicker, respectively. “You touch the paddle and the gear changes with immediacy,” said Link. “The shifts happen so quickly and without delay that it almost feels like an extension of your reflexes. It’s a much more involving experience for the driver that really helps improve confidence and performance on the track.” Hundreds of hours were spent integrating the 10-speed’s shift performance with the unique power band of the ZL1’s supercharged 6.2L LT4 engine, which is estimated at 640 horsepower and 640 lb-ft of torque. The 10-speed also has a numerically lower top gear ratio than Camaro’s eight-speed automatics, which allows the engine to run at a lower speed on the highway, enabling even greater efficiency. Creative packaging Creative packaging solutions, which had to accommodate another clutch in comparison to the eight-speed, allow the 10-speed to be the approximate size of Camaro’s other eight-speed transmission. It uses four simple gearsets and six clutches: two brake clutches and four rotating clutches. That’s only one more clutch than the eight-speed, despite having two more forward gears. It is also the latest transmission with an all-new, proprietary electronic control system and performance calibrations. The calibration is unique for the ZL1’s high-performance-oriented driving experience, while additional applications will feature calibrations matched to their respective performance ranges. Additional highlights:
The 10-speed will be produced with an all-new manufacturing system at GM’s propulsion manufacturing facility in Romulus, Mich. It’s part of a $323-million investment in the facility, which employs 850 hourly and salaried workers. Holy Shift! A Look inside GM’s new 10-Speed Automatic Advanced design, GM control system support capability, enhanced efficiency General Motors May 11, 2016 DETROIT – Engineers for the new 10-speed automatic transmission available in the 2017 Chevrolet Camaro ZL1 built on the experience of previous, critically acclaimed Hydra-Matic multispeed transmissions to push its performance, refinement and efficiency advantages to a new threshold. The 10-speed is an all-new design – and the first-ever application in a car – with a wider, 7.39 overall gear ratio spread, that enables the ZL1’s supercharged engine to remain at optimal engine speeds during upshifts. “With world-class shift times on par with the world’s best dual-clutch transmissions and the refinement that comes only from a true automatic, the 10-speed delivers incomparable performance on and off the track,” said Dan Nicholson, vice-president, GM Global Propulsion Systems. “It also leverages the experience of our other multispeed transmissions to deliver that performance with greater efficiency as its use expands into other vehicles.” The wider overall ratio enables a lower numerical top gear ratio – an attribute that reduces engine speed on the highway, which contributes to greater fuel efficiency than a comparable eight-speed transmission. Improvements in spin loss complement the optimized gearing, further enhancing efficiency. And while the Camaro ZL1 will be the first GM vehicle to offer the new 10-speed automatic, designed for rear-wheel-drive applications, it will be available in eight additional vehicles by 2018. Additional highlights:
Architectural features and packaging Thousands of hours of computer-aided engineering analyses were made during the development of the Hydra-Matic 10-speed transmission, driving a comparatively compact design envelope comparable to the eight-speed automatic. A one-piece aluminum case with an integral bell housing helps reduce weight and enhance powertrain stiffness, while a unique 260mm, integral turbine clutch torque converter design reduces complexity and helps make the converter thinner, which contributes to the transmission’s packaging. The 10-speed has four simple gearsets and six clutches: two brake clutches and four rotating clutches. That’s only one more clutch than the eight-speed, despite having two more forward gears, contributing further to the compact packaging, while also improving spin losses to enhance fuel efficiency. A unique triple-clutch assembly in the middle of the 10-speed’s architecture is a primary enabler for packaging 10-speed content in the same space as GM’s six- and eight-speed transmissions. The 10-speed also features a variable-displacement vane pump, which optimizes transmission fluid pressure, based on speed and load, to enhance efficiency. 7.39 ratio spread and faster upshifts The new 10-speed’s greater overall performance and efficiency are due primarily to its wider 7.39 overall gear ratio spread, which enhances off-the-line performance with a more aggressive first gear ratio than GM’s eight-speed automatic. Smaller steps between the gears also help the engine maintain the optimal speed for maximum power at almost all speeds, especially when exiting a corner on a track. Adaptive shift controls such as Performance Algorithm Shifting and Driver Shift Control enhance performance driving. Performance Algorithm Shifting (PAS) monitors how assertively the driver is using engine output to determine at what engine speed to upshift or downshift. Driver Shift Control allows the driver to shift the transmission via the steering wheel-mounted paddle shifters. Electronic safeguards prevent over-revving if the wrong gear position is selected, but relies on the driver to make upshifts or downshifts. Gear changes are mainly executed with clutch-to-clutch action, where an “on-coming” clutch is engaged and an “off-going” clutch is released in a precise manner to achieve the ratio change. Certain key shifts, however, are made with a freewheeling action, such as 3-1 downshifts, where a plate clutch is actively disengaged while a mechanical freewheeler clutch automatically engages with optimum synchronization. The torque converter is 260mm in diameter and features a lock-up clutch. It also uses electronic controlled capacity clutch (ECCC) technology, which employs a small, regulated amount of slip to dampen out engine pulses for a smoother running drivetrain, especially during shifting. Reduced spin losses and new transmission fluid Friction-reducing design features, including all-new ultra-low viscosity transmission fluid, internal thermal bypass, minimal number of non-applied clutches and other lower mechanical spin losses, contribute to the 10-speed’s effect on improved vehicle efficiency. The low-viscosity fluid helps reduce fraction across the full temperature operating range, which enhances fuel efficiency. Additionally, the internal thermal bypass allows the transmission to warm up faster to its optimal operating temperature, further contributing to fuel efficiency. GM control system World-class shift time quickness and responsiveness are accomplished by leveraging the base transmission hardware in concert with GM exclusively developed algorithms, software and calibrations. An externally mounted electronic control module executes millions of controls instructions every second.
2023 GMC Canyon Elevation 2020 Chevrolet Colorado W/T Extended Cab (State-issued) |
05-11-2016, 08:40 AM | #2 |
Drives: SS,PaceCar,ZL1,1LE,C7Z51,Z06,17-ZL1 Join Date: Jun 2009
...Very Cool..
Fenwick Hockey ...FTW!..Thanks for sharing |
05-11-2016, 08:52 AM | #3 |
Drives: Chevys at the limit Join Date: Nov 2010
Sure would be cool if they offered a software update that made the A8 paddles a little quicker to respond also.....
05-11-2016, 08:53 AM | #4 |
I used to be Dragoneye...
Hmmmmm.....faster shifts than PDK (and they called that out directly, wow!)...higher efficiency...reduced friction losses...reduced spinning losses...lower engine speeds in higher gears...the ZL1 might just escape the gas guzzler tax in automatic form...and that was one of the prerequisites to me choosing this option....
Damn, Chevy....the home-runs just keep coming. Can't wait to get one of these out on the track! Please, please, please stay cool! |
05-11-2016, 08:58 AM | #5 |
Drives: Slow Join Date: Mar 2016
Is it strictly software? If not, it would be cool if they had the hardware updates too.....
2016 Toyota 4Runner
2017 Camaro ZL1 |
05-11-2016, 09:02 AM | #6 |
Drives: Getaway Special Join Date: Jan 2013
Curious if this is a "sealed" transmission and limitations on fluid replacement frequency. I did not see that addressed, but curious minds want to know!
Sip:
05-11-2016, 09:19 AM | #7 |
They all seem to be sealed nowadays....is that a fill hole, do you think, up at the top/midway down the casing?
05-11-2016, 09:28 AM | #8 |
Drives: 21 Bronco Join Date: Jun 2012
This was co-developed with Ford correctly?
I know Ford is putting it in the Raptor for their first application. I think its pretty cool that this trans is going to see such different applications for its first uses |
05-11-2016, 09:42 AM | #9 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Ford developed this 10 speed unit. GM developed the 9 speed front wheel drive transmission.
05-11-2016, 09:44 AM | #10 |
05-11-2016, 09:51 AM | #11 |
Co-developed is the right word. But basically Ford took lead building the 10-speed and GM took lead on the 9-speed for FWD applications. Both are relying on tech and processes developed by the other.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
05-11-2016, 10:01 AM | #12 | ||
Co-developed. This is not a "Ford" transmission, any more than it is a "GM" transmission. And each company developed their own controller software/tuning/programming for the transmissions. |
05-11-2016, 10:20 AM | #13 |
Drives: 2018 ZL1 6M, Silverado High Country Join Date: Oct 2008
Very cool info Wyndham! Gonna be a sweet trans. Yeah I heard this 10spd was developed by both Ford and GM.
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof 2019 Silverado High Country, Daily Driver |
05-11-2016, 10:26 AM | #14 |
Sure, Ford and GM codeveloped the 9 and 10 speeds. Ford took the 10 and GM the 9. That isn't a knock against either company.
