01-02-2020, 12:28 PM | #1 |
4 piston brembo brake pads
so ive used to stock brembo brake pads and also the powerstop track day brake pads and just wondering what all you other ss 4 piston guys have tried/used on the track? thanks
01-06-2020, 11:09 AM | #2 |
nobody? lol
01-06-2020, 11:25 AM | #3 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Initially Hawk's DCT-70 Front/ DCT-60 Rear, Now... Hawk DCT-70's all around!! I like the increased bias in the rear with my Vert anyways. Be advised you will cook the dust boots. I currently have RB tooling some high temp ones to try with their cut stainless pistons to help with this. Stay posted for their release...
01-06-2020, 11:50 AM | #4 |
any reason your sticking with the 4 piston setup and not going to 6 piston?
01-06-2020, 12:29 PM | #5 |
Honestly not knowing what I'm missing??, and of course the money. Other than that I haven't felt the need for more braking where my current set up hasn't done the job? Therefore I see it's just unnecessary weight that I don't need. Again thats said without having felt the true benefit of 6 pots and larger rotors. Given the opportunity my tune may very well change! lol
01-06-2020, 01:06 PM | #6 |
yea ive been looking at upgrading to 6 piston so i always keep an eye out for used 1le/zl1 kits
01-07-2020, 11:17 AM | #7 |
Drives: 16' Camaro SS Join Date: May 2019
Currently using Raybestos ST45 in front and ST43 in back. I've been pleased with this setup and get pretty good pad life. Went through stock pads and Power Stop Track Day pads quickly during HPDEs. Car is stock except for GM Performance lowering kit and sway bar kit and running on Michelin PS4S. Should add that I run Motul 600 and flush the fluid regularly. Also have Vorshlag Camber plates and well worth the upgrade for extending tire life.
01-07-2020, 11:31 AM | #8 |
yea i may try these next or upgrade the front setup well see! where did you order yours from? kns or porterfield?
01-07-2020, 11:47 AM | #9 |
I've purchased from both but the most recent ST45 in front were from KNS.
