05-15-2020, 05:18 PM | #15 |
Next step just put on the stock throttle body and if that's the case then there's a problem with the electric motor in the throttle body. Try to avoid a trip to the dealer because this is something much more simple.
05-15-2020, 05:29 PM | #16 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Well just ran scan tool and this is what came back
Confirmed PO303 Cylinder 3 Misfire Detected Pending PO303 Cylinder 3 Misfire Detected Permanent PO303 Cylinder 3 Misfire Detected Engine is to dam hot to try and make sure all the ignition wires are on. Tried resetting the codes and it doesn't reset. Seems to me that means the problem still exists. Will make sure all the ignition wires are seated tomorrow and try the scan tool again. Although could be something more than that! Using OBD Fusion App reading my Kiwi3 OBD |
05-15-2020, 05:30 PM | #17 |
Two Lane Blacktop
Drives: '18 Camaro 2SS Join Date: Jul 2019
Exactly just keep reversing the mods start back to stock it should clear. Will be at least able to drive the car. And if it runs it’s one of the three changes.
05-15-2020, 05:32 PM | #18 |
05-15-2020, 05:37 PM | #19 |
Check number three plug wire at the coil and at the spark plug...obviously loose. Second one from the front on the driver's side
05-15-2020, 06:07 PM | #20 |
Drives: 2017 ZL1 Join Date: Jan 2017
Note, it is very possible a plug wire pulled out from coil pack, check all plug wires both sides. I've had this happen before. #3 should be 2nd one back from front on drivers side.
05-15-2020, 06:11 PM | #21 |
Thanks, will check tomorrow and report back! If it could be so simple!!!!!!!!!!!!!!
05-15-2020, 06:14 PM | #22 |
Seems really strange that warning messages for the stabiltrac and rear axle would go off because of a misfiring cylinder.
05-15-2020, 06:33 PM | #23 |
very common!
05-15-2020, 07:30 PM | #24 |
Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
I had thus issue. Removed the throttle controller and all good
05-15-2020, 08:27 PM | #25 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Somebody just went through this. For that person it happened to be the plug. But like the other guys said. Check to make sure those wires are properly seated.
05-15-2020, 09:11 PM | #26 | |
Drives: 2018 Mosaic Black Metallic ZL1 A10 Join Date: Sep 2017
By the way, there are 6 ZL1 and 1 ZLE going to the Rezoom event at VIR on June 6-7. You should sign up. |
05-15-2020, 09:49 PM | #27 | |
05-16-2020, 07:27 AM | #28 |
Drives: '22 Summit White ZL1 A10 Join Date: Aug 2019
Damn Tony......looks like neither one of us can catch a break......had those same mods going on this weekend.....gonna wait to see what you come up with......
