Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 10-28-2018, 09:36 PM   #15
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Originally Posted by Royal Tiger View Post
I was thinking of the Fast intake and a ported throttle body before a cam. Still up in the air as the cam is pricey.
Ya...I'm looking at doing some suspension mods first before a cam. I wonder what the top 2 or 3 mods I can do to really get the car to plant on launch.
rontammy0 is offline   Reply With Quote
Old 10-28-2018, 10:26 PM   #16
GossipSquirrelJelena
Drives: 2015 Mustang GT. Supercharged.
Originally Posted by rontammy0 View Post
Yep same as the GT 350r that I beat was. Fbo Mustangs are rockets top end. Boss intake sure helps.
Im strapping a 18 intake on my car tomorrow. Tests show it flows very similar to a GT350 intake. But they only cost $300 bucks compared to a $1100 invest on the Gt350. Im hoping it puts me in the 700-715whp range.
GossipSquirrelJelena is offline   Reply With Quote
Old 10-28-2018, 10:31 PM   #17
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Nice! Was it a S550 5.0 or S197 5.0?
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 10-28-2018, 10:32 PM   #18
Get a good set of drag shocks. Think Lakewood or Viking. Then unhook your front sway bar. Cheap, easy effective.
Old 10-29-2018, 09:08 AM   #19
rontammy0
I'm hearing this a lot with my Mustang friends. And yep they flow really well and cheap.
Old 10-29-2018, 09:09 AM   #20
rontammy0
S197 . 2011 Mustang GT 6sp with full boltons.
Old 10-29-2018, 09:11 AM   #21
rontammy0
Thanks....I was thinking rear trailering arms. Never thought of drag shocks. When I un hook the front sway bar just it still stay in.?
Old 10-29-2018, 01:40 PM   #22
Nb1081
Drives: 10 2ss/rs
Some 90/10 fronts 50/50 rear
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 10-29-2018, 01:49 PM   #23
rontammy0
What brand I wonder. I forget which one needs the v6 spring.
Old 10-29-2018, 03:28 PM   #24
Yes sway bar stays mounted. Just unbolt the end links. Unless you just want to remove it for weight reduction. The car rides fine without it. If you wanna go that route. I used lakewood on the 95 race car.
And you can see from the pic below. They worked.
Old 10-29-2018, 03:58 PM   #25
rontammy0
Was that the rear traileringv arms?
Old 10-29-2018, 04:10 PM   #26
You only need to unhook the sway bar on the front of the car.
Old 10-29-2018, 08:18 PM   #27
rontammy0
Ok
Old 10-30-2018, 01:09 PM   #28
WoodBoss
"Old School"
Drives: 2010 2SS L99
BMR trailing arms and toe rods are fairly inexpensive and not bad to put in. Drag shocks are nice but very pricey. Skinnies up front and MT Street R in the rear at 17" are a really good combination and saved me 50 lbs off the stock wheels and tires.
WoodBoss is offline   Reply With Quote
