05-02-2018, 02:56 PM | #1 |
Drives: 2016 Camaro 1SS Coupe Join Date: May 2018
Considering Used 2016 SS. Is this normal?
Hi Guys!
Newbie here, I've been a reader of the forum for a few months but I just I joined recently as a member because I am considering buying a 2016 Camaro SS with 40,000 miles if they get me the right price but I was wondering a couple of things. I test drove it for a while and all the drivetrain suspension and steering seems fine. Took it to the mechanic and he said he couldn't find anything wrong, the underneath looks good as well, only couple things I noticed: At the beginning of the ride, the rev needle was jumping a lot and really fast, after a while the problem was gone, could it be because the car was cold, is this normal on yours? Other thing is after using it for a while opened the hood and there was a whistling/high pitch noise coming from the engine, dealer said it was the band but that it was normal but I haven't heard any other car making a similar noise, does your car makes this noise? I uploaded a video to youtube to show it: https://youtu.be/nnNCaCjkYCA Do you think it is actually the band or another serious problem? Also, there is no crushed metal from a bad lift or scraped rockers but both doors are misaligned with the fender at the bottom (pictures attached) could I be that the hinges need adjustments or would it be something else? Thank you!! |
05-02-2018, 03:14 PM | #2 |
Deadpool
Drives: 2016 camaro lt rs m6 redhot Join Date: Sep 2016
Crazy you posted this,i just took my car in to have a hinge replaced yesterday and had the same issue after they did the job,i came to the conclusion that it just needs to be adjusted,i made an appointment to have it looked at again
05-02-2018, 03:17 PM | #3 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
fenders can be realigned, the noise is not normal. Hydraulic tensioner is leaking. wipe it with a rag to confirm the presence of hydraulic fluid. then have it replaced under warranty.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
05-02-2018, 06:00 PM | #4 |
Drives: 2016 2SS, Summit White, A8, NPP Join Date: Apr 2013
It is great that you found out the normal dealer response to all issues of "It's normal". Nice to get that out of the way.
05-02-2018, 08:03 PM | #5 |
I say walk away from that car. If I saw and heard what you did, my gut wouldn’t let it go. There are other cars out there, don’t step into something that needs to be fixed right out of the gate.
05-02-2018, 08:19 PM | #6 |
Drives: Soon to be Camaro Join Date: Mar 2018
Walk away.. Motor does not sound right.
05-02-2018, 09:31 PM | #7 |
Drives: 2023 2SS Convertible Join Date: May 2009
Don't walk away, run! Don't buy a car that already has a bunch of issues you can see.
-Geoff
05-02-2018, 10:43 PM | #8 |
Thank you everyone for the feedback, I guess you guys are right, it was an automatic anyway hopefully I find a manual later this year lol.Another thing is that dealer hired someone to fix the wheels but they were ALL 4 curbed a lot of times each so car was probably poorly driven. I have attached another picture in this post, I know is a sport car but compared to yours, does it look normal for 40k miles or abused?
Thank you so much for the detailed reply, I'm not saying you're wrong and really appreciate your response but may I ask how you came to that conclusion? Did it happen to you? Is it a common issue that is often fixed by warranty or is not common and probably caused by abused engine? |
05-02-2018, 10:51 PM | #9 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
Run away from this one. Was likely a rental that got auctioned off and it has been hammered on. That engine sounds like a tractor, not a smooth powerhouse!
05-03-2018, 12:15 PM | #10 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
I agree with what others have said, walk away. You don't want to do business with any dealer that says that noise is normal. Also agree that this sounds like a rental. 1SS in red with auto sounds like a fleet vehicle. I would suggest you keep looking.
05-04-2018, 11:03 AM | #11 |
Gotta watch out for them donkey stomped rentals...they are everywhere!
2016 NFG 1SS A8
05-04-2018, 11:36 AM | #12 |
Thank you Al Oppenheiser!
This, unlike the other issues, is normal on our cars. The black stains are caused by condensate dripping from the weep holes at the front of the suitcase muffler.
05-04-2018, 05:27 PM | #13 | |
05-04-2018, 06:12 PM | #14 | |
You guys are absolutely right, it was indeed a rental. I didn't mention it on the first post hoping people would not tell me immediately to run away without even looking at video/pictures but that was the main reason why I was on 90% that is a NO go and 10% "considering".I still took the time to take it to the mechanic for a free inspection because I also wanted to make a loong drive test to really see if I would like the camaro coming from a little fwd mazdaspeed with really big windows but I guess the mechanic free inspection was a "free" useless inspection.
