08-02-2023, 05:15 PM | #365 | |
Drives: 6th Gen LT1 Join Date: Jun 2023
Base price will include LT1 simulated manifold. To get the LT2 airdrop you have to pay a subscription of $87 a month. |
09-20-2023, 02:30 PM | #366 |
Drives: 2022 SS 1LE Join Date: Apr 2022
I've tried searching for the torque specs for the LT2 intake, but can't find them on here. Anyone know what they should be? I'm getting my LT2 from rockauto tomorrow and shaving the underside and adding the port in the back hopefully this weekend. What is the consensus on keeping the foam padding under it?
Any other helpful advise for this mod? |
09-20-2023, 02:40 PM | #367 |
199
Drives: like a granny Join Date: Apr 2013
Just installed my LT2 intake after the first one I received was cracked. Pretty basic install and I am beyond happy with the feel of the car afterwards. Pulls hard to 6500RPM and the shifts are awesome then it keeps pulling each gear. I didn't notice any loss of power anywhere and partial throttle response feels improved. I am using the stock throttle body still. Beyond happy with this mod!
https://youtu.be/qA5pWdQIBtk
2023 Silverado LZ0 Duramax
2021 Shock SS 1LE A10 www.youtube.com/@DemonWorksPerformance Anderson composites coupon code : Demon |
09-20-2023, 03:24 PM | #368 | |
09-20-2023, 03:26 PM | #369 | |
199
44 in lb then 89 in lb
09-20-2023, 03:42 PM | #370 |
Roger that, thank you very much. Again, your video was quick, but informative. Thumbs up.
09-20-2023, 04:11 PM | #371 | |
199
Thank you! I watched every single LT2 intake install video and a few were tough to watch, my goal was to get straight to the points. I have a different youtube channel with the 3.0 Diesels, I do the same there and it seems to be appreciated. Hopefully my video at least helps a few people out on pulling the trigger on this intake.
09-20-2023, 04:15 PM | #372 | |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
09-20-2023, 05:57 PM | #373 | |
Hey, what scanner is that you are using? Found it, nevermind. |
09-21-2023, 01:26 PM | #374 | |
199
stock tune, all I did was what was shown in the video. Been driving the car and still very happy with the results. There's so much negative on the intake and dyno runs, seat of the pants full throttle and light throttle regular driving has been enjoyable.
09-21-2023, 01:27 PM | #375 | |
199
Glad you found it, I like the tool.
09-21-2023, 05:45 PM | #376 |
That tool is 465-- I was looking at the 258 one. Dang, yours has crank relearn. Sheesh, you ARE the dealer shop. lol Since I do not have this tool and won't when I install my LT2. What can I do to relearn the TB and/or intake? I have Trifecta tunning and I will ask them to calibrate my E85 and the intake, but do they "teach" my car?
09-23-2023, 07:18 AM | #377 | |
They might be retarding around peak torque to bleed cylinder pressure to get more timing in. If you’re running e85 you don’t want that, you want cylinder pressure and the timing. If you’re not flex fuel, retarding the cam might work out for u
09-23-2023, 09:35 AM | #378 | |
199
