02-22-2022, 10:41 PM | #1 |
Drives: Camaro ZL1 1LE Join Date: Jun 2021
2018 ZL1 1LE Drag Launch
Hi Guys,
I just purchased not to long ago a stock 2018 ZL1 1LE with a 6 speed and has stock tires. I am going to the drag strip on friday with some buddies and was wondering the best practices for getting a great launch. Any feedback on whats working well would be appreciated. Thank you |
02-23-2022, 12:35 AM | #2 | |
Drives: 2017 Camaro ZL1, 6M Join Date: Dec 2019
and Also get familiar with the No-Lift-Shift feature. Here's a vid of a launch and a no-lift 1-2 shift. Takes a while to get used to NOT lifting your foot off the gas while clutching and shifting. I don't recommend using PTM (in any mode) alone/by itself without Launch Control enabled because wheel slip is shut down by PTM alone so the car will bog hard six feet into your launch. You will need to be in either Competitive Driving Mode or PTM to be able to engage launch control though. All systems off will require good right-foot throttle control; consider Competitive Driving Mode if you want full power instead of the car managing the traction because it's a bit safer than "all nannies off" as it will allow 100% power but will try to prevent a spin-out by selectively braking a wheel as required... Also be aware that there is a manual setting to alter the launch RPM and allowable tire-slip of Launch Control. Run about 26 PSI in the rear tires. Last edited by Robster; 02-23-2022 at 12:54 AM. Reason: hidden link removed |
02-23-2022, 11:39 AM | #3 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
You will need to make sure those tires are nice and warm. So a good 5 sec burnout should do it. If they aren't up to operating temp, they won't grip too well.
The tires and the ZL1 1LE are made for a road course, not a drag strip. Remember that. The stiff suspension doesn't work well in launching the ZL1 1LE. I would advice against launch control. It sucks in our car, unless the M6 launch control works better than the A10. I'd say, try both and see what works best. |
02-23-2022, 12:29 PM | #4 |
Drives: Faster than yours Join Date: Nov 2021
OP: I bought a Lamborghini Huracan, help me with rock crawling this weekend with my buddies
02-23-2022, 01:02 PM | #5 |
Drives: Tracks: 18' ZL1 1LE Join Date: Mar 2018
Best practice would be to hit up road courses since you bought a road course car.
18' ZL1 1LE Red Hot track toy
Castrol SRF Ported TB/Rotofab dry intake AWE Track w/PLP APR GTC300 wing / Singular Endplates ASC Splitter / PA tunnels MFR Engineering Custom Diffuser Race Louvers Fender Vents APEX SM10 & ARC8 For sale: 2018 OEM ZL1 1LE Wing 12' Nissan GT-R SOLD |
02-23-2022, 01:18 PM | #6 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Nailed it; wrong car for what you're wanting it to do.
02-23-2022, 01:20 PM | #7 | |
Sarcasm loading --------
your launch is going to be very poor, the tires dont even begin to grip until they are hot and a burnout most likely isnt going to heat up the tire through enough to maintain the heat through the lights. if you have tire warmers or its 90 degrees outside where you are at you are good. hopefully they will put some adhesive on the track for you.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
02-23-2022, 02:07 PM | #8 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
02-23-2022, 02:09 PM | #9 |
02-23-2022, 03:14 PM | #10 |
Drives: E92 BMW M3 Join Date: Oct 2012
LOL, how dare you want to drag race your track car. Unacceptable! If you do dare do it without permission, you better not have fun!
J-Rod Built and Matt@FSP Tuned |
02-23-2022, 03:17 PM | #11 |
OP asked a simple question and he wants to enjoy his time with his buds at the dragstrip, I'm not sure he needs to be lectured on what the car he bought is made for. We don't even know if he cares if it does worse than a "normal" ZL1
Perhaps a good smoky burnout will give him a better launch, at the cost of some tread.
02-23-2022, 05:34 PM | #12 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
1. Lower the cold air pressure down to 26 psi. 2. Drive around the the water box, then back into it, do a 3-5 second burnout. 3. Pull up to the lights as soon as possible and hope someone in the opposite lane doesn't decide to make a sandwich. 4. Leave at an rpm slightly above idle and slip out the clutch (don't side step it). 5. Don't get frustrated if your 60' times suck and your mph sucks.
02-23-2022, 06:38 PM | #13 | |
02-23-2022, 09:33 PM | #14 |
Who Needs to KNOW?
Personal experience on ZLE w pilot sports. Launching sucks. Wheel hop is always there, throttle out wont fix it either. No lift shift into second sometimes tosses rear end sideways - be ready to correct and let off the throttle and try again next run unless you want to hero mode and run 13's into the wall.
If you get launch OK.. rest is cake. Get there early, get in as many runs as you can. Launch mode.. practice somewhere deserted - never got it to work worth a lick.
ing for grip.
