04-30-2019, 04:16 PM | #1 |
Side curtain airbags deployed
Add another 2011 Camaro to list of side curtain failures. I had TC off low speed oversteer, slid back the other direction and they went off. By the time the bags deployed I had the car going in right direction. 4 wheels never left the track, no rumble strips, etc.
05-01-2019, 01:30 PM | #2 |
Drives: 2013 camaro zl1 aka the Reaper Join Date: Apr 2018
is this a common issue with the 5th gens?
05-01-2019, 01:58 PM | #3 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
there have been a few reports here on the forum of this. You can push these cars pretty hard on the track, with the right setup and the ECM thinks you are "out of control" and does what it's programmed to do to protect your life. Even a few calls from OnStar to see if you are alright since the car either launched very hard or took a turn on a track at a ridiculous rate.
05-01-2019, 03:30 PM | #4 |
My car was not pushed hard. I am still very much novice. This was a fishtail and the airbags popped. It is ridiculous that it even happened.
05-02-2019, 01:18 AM | #5 |
#551
Drives: 2011 Camaro SS Join Date: Apr 2010
https://youtu.be/5LUDSr67Q2w
Happened to me I was very confused when it happened lol, I just cut them out and went back out
05-02-2019, 01:49 AM | #6 |
Drives: Camaro 1LE Join Date: May 2018
Oil pump failures, air bag going off for no reason... I'm starting to wonder now
05-02-2019, 10:40 AM | #7 | |
Was there ever a resolution from GM, or did you have to pay for repair? -Chris |
05-02-2019, 11:35 AM | #8 |
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White Join Date: Jan 2019
I watched another video where this happened to an individual that was running cut outs. They pointed the exhaust to the exterior of the car near the mid point or where the door engages the latch. This is the area where the side curtain air bag sensors are apparently located. The continuous noise from the exhaust supposedly set them off.
Levon H. Bone Stock |
05-02-2019, 12:08 PM | #9 |
05-02-2019, 01:06 PM | #10 |
Chevy Enthusiast.
Some older but dated info.
https://www.thetruthaboutcars.com/20...ing-the-party/ 1 2018 ZL1 as well.
05-02-2019, 01:38 PM | #11 | |
05-02-2019, 02:18 PM | #12 |
I do not know what will happen in my case. I had my mechanic price out the bags as there are plenty out there used. Each bag will cost about $350. Looks like about $1500 for parts
Silveradoss573 - After I get car fixed up, I will install race harness and disable airbags at track (fuse pull) |
05-02-2019, 02:28 PM | #13 | |
I thought I saw somewhere that pulling the fuse or fuses doesn't work???? |
05-02-2019, 02:55 PM | #14 |
This happened to a guy in a Gen 5 SS back in January at MSRH for a NASA weekend. Just going down the straight, no big bumps or rumble strips.
I pull my fuse now for track time. Airbag light comes on but who cares.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR CTSV/ZL1 front calipers/rotors + G-Loc Forgestar CF-5 19x11 |
