Old 04-17-2021, 08:55 AM   #1
Liquidstone
Liquidstone's Avatar
Drives: 2018 ZL11LE
Fuse popping
Hey guys so I'm hoping to pick some of your brains.
Last year we had some private rental days on the strip. I figured what the heck and joined. I took out the passenger side seat and rears, to not only lighten the car but mostly to make room for my drag tires, tools, cooler, and Jack. However once I got back home and reinstalled everything I keep popping the fuse that controls the passenger power seating, and it seems to effect the heated and cooled seats on both sides. I suspect there is a short somewhere.
Liquidstone is offline   Reply With Quote
Old 04-17-2021, 10:27 AM   #2
ZLE dude
Drives: '18 ZL1 1LE
I'd probably pull the seat back out and make sure you didn't pinch a wire. I assume the plug went back in fine, but if not, I'd also check to make sure you didn't get anything stuck inside the plug for the seat.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 04-17-2021, 01:46 PM   #3
Liquidstone
Drives: 2018 ZL11LE
I have done a quick visual of the wire....it runs under the carpet then along the side board. I'm assuming something has happened because I was climbing in and out of the car that way on the track.
