03-19-2022, 08:33 PM | #15 |
Drives: 2010 Camaro 2SS Join Date: Jan 2019
Could it be a starter by any chance
03-19-2022, 09:05 PM | #16 |
It’s doubtful that a bad starter would cause all of the symptoms you described and pretty much no way it would cause the general error code.
03-19-2022, 09:29 PM | #17 |
Grounds, ground, grounds - Check your grounds!
Also, make certain every single connector that you had to disconnect is fully seated and engaged. These cars are finicky as F when the electrical system is not exactly right. Also make sure to check that none of the wiring or harness is pinched or caught anywhere or between anything. Autozone, Advance, O-Reilly, etc... can check for bad cells and cranking amps in a battery and give you a printout. Once you have done everything above...check your grounds again! This car has a ton of grounding points and some of them are tiny little 16-20ga wires that can be easily missed But I bet it's the battery EVERY PART MARKED WITH A '2' IS A GROUNDING POINT (And 5). Unfortunately I only have the underhood diagram, so hopefully someone else has some other grounding point diagrams for trans tunnel area:
03-20-2022, 06:53 AM | #18 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
The only electrical component moved doing a converter is the starter. There is a chance that something for moved/pinched in the process, but the other symptoms point towards the battery. It was probably unplugged to do the work. Check the terminal connectors as well.
... Then get a new one |
03-20-2022, 08:25 AM | #19 |
Battery, battery.... Like said above, these batteries make the car do weird things when they go bad. Just because it seems good, it is not. Way past time for a new one. Good luck...
03-21-2022, 06:21 AM | #20 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
03-21-2022, 01:20 PM | #21 |
I replaced the battery and checked the grounds and I got rid of the signs. But after a couple minutes of running I get a Battery Saver Active message on my dash.
03-21-2022, 03:34 PM | #22 |
Check the voltage at the battery when it is running. Might be a ground keeping it from charging or a bad alternator.
03-21-2022, 03:41 PM | #23 |
The volts are around 11.8-12. The sign pops up when I have the ac and lights on. I had it running for 30mins to a hour and drove a about 15 mins and it pops up soon as I put it in drive.
03-21-2022, 04:47 PM | #24 |
11.8-12 volts is to low and indicates a charging problem. I would check it with a separate voltmeter.
03-22-2022, 07:26 AM | #25 |
A fully charged battery by itself has 12.6v, so your definitely discharging the battery when running. Should be no less than 13v running. Sounds like the alternator is bad, probably just a coincidence it happened after installing the converter.
05-31-2022, 05:57 AM | #26 |
Might be the starter. It’d do nothing been cranked other than a click when turned from accessory to on like yore starting it. My GMC Sierra starter recently went out. No screeching. Only warning sign was that it wouldn’t start then most times it would. Towards end of its life it would stop more than it’d start.
Life is short, drive it like you stole it! |
05-31-2022, 10:53 AM | #27 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I'm leaning towards what nota45 just said.
Discharging WHILE RUNNING is mostly an alternator. I don't know about a bad module doing that, no experience there but usually a bad alternator. A shorted internally battery might do that but I'd be surprised it holds 12v if it were the battery being that bad. |
12-12-2023, 03:24 AM | #28 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I'd say definitely the alternator. Mine has over 14 volts when running. Also I would highly recommend replacing it with an ac delco only.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
Tags |
cam, engine light, help me, torque converter |
