09-22-2022, 11:09 AM | #1 |
Drives: 2007 Honda Civic Join Date: Apr 2018
Required service on fluids
I have a 2019 1LE with less than 3,000 km. Just got a phone call from the dealership about changing the fluids on the car. Considering how low my milage is, is there a benefit to changing the fluids as they have timed out, or should I just wait?
09-22-2022, 11:14 AM | #2 |
Thank you Al Oppenheiser!
Depends on what you're doing with the car.
My advice is to follow the manuals: * For regular use, the owner's manual. * For track use, the track prep manual. |
09-22-2022, 02:38 PM | #3 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Main things to look at are:
How many miles have you driven since the last oil change Has it been 1 year since your last oil change Have you been doing any racing with your vehicle I'm going out on a limb and say you don't drive the car much (being in Canada) and you don't do much racing? The car does have a oil life meter and goes off how you drive and time. Give it a look. When was the last time you changed your oil (time wise)? If it's been more than a year then you should do so. It's because with the oil sitting there, it breaks down and the additives in there to help the engine parts stay lubricated and protect them isn't as good as it was 1 year ago or 2 years ago, etc. I'm sure they'll be some that say it's a bunch of BS but oil is the lifeline to engines, mostly, so if it's not working as intended then your engine is going to suffer. Your call as it's your car. |
09-22-2022, 03:45 PM | #4 |
Shadow Gray '19 ZLE M6
Diff fluid is important. There will be metal shavings in the fluid before initial change.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
09-22-2022, 04:08 PM | #5 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
What does the oil life percentage show? If it's been that long, I'm surprised it's not 0.
I'd definitely change the diff fluid as suggested above. |
09-22-2022, 05:04 PM | #6 |
oil change diff fluid change maybe brake fluid if its been sitting for awhile
09-22-2022, 05:41 PM | #7 |
I don’t drive my ZL1 much anymore and I haven’t changed the oil in almost 2 years and don’t have that many miles on it but planning to change it again in October or November. The oil looks fine to me as I am running Lucas Synthetic 5w30. I have oil I bought last year in October that is still sitting waiting to be changed.
09-23-2022, 01:39 AM | #8 |
Drives: 17 ZL1 Black M6 Join Date: Sep 2016
09-23-2022, 01:59 AM | #9 | |
2020 Shadow Gray 2SS
Components... Not...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
09-23-2022, 08:28 AM | #10 | |
09-23-2022, 11:17 AM | #11 |
Drives: 2018 ZL-1 Join Date: Jan 2018
Here is my service schedule. The car has many BMR suspension components, so the alignment parts list is shorter than stock.
Some will think this is excessive. However, this car is a keeper. I average less than 3000 miles a year, and I spent $20K in upgrades on the car, so I want it to be in perfect condition. ZL-1 SERVICE SCHEDULE OIL CHANGE – EVERY 2000 – 2500 MILES TRANSMISSION – EVERY 6,000- 10,000 MILES DIFFERENTIAL – EVERY OTHER OIL CHANGE BRAKE FLUID – DOT 4 – EVERY COUPLE OF YEARS AIR FILTER – EVERY YEAR COOLANT – EVERY FEW YEARS SUPERCHARGER COOLANT CIRCUIT – EVERY FEW YEARS ALIGNMENT – AT DEALER - EVERY 5000 MILES OR AS NEEDED. REPLACE 4 STRUT BOLTS AND NUTS, AND 2 REAR LOWER CONTROL ARM BOLTS AND NUTS AT EVERY ALIGNMENT (BOLTS ARE SINGLE USE ONLY) Part Numbers: Front Shock Bolts: 11547494 – 4 NEEDED + NUTS Rear Camber Bolt: 11547215 – 2 NEEDED + NUTS BALANCE TIRES – EVERY ALIGNMENT OR AS NEEDED. CABIN FILTER – EVERY FEW YEARS OR AS NEEDED |
09-25-2022, 11:30 AM | #12 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Oil gets diluted with fuel and water (from humidity). It accumulates dirt, metal, ie corrosion, rust, combustion by-products, from engine internals smaller than what gets filtered. Stretching out the low cost of fluid changes seems a bit silly if you think about the total cost of the car. Change at a mininum of once a year if you don't track the car and are low use.
Transmission and diff last over years if not tracked because there is no combustion process involved. Track use elevates the temperature much higher than street use which can break down the oil. Also there is more wear debris in these unfiltered components.
