Roto-Fab
Old 09-21-2022, 05:05 PM   #1
ss camaro-monte
Drives: 2015 camaro 2ss, 87 monte ss
Aftermarket Cylinder Head Help
Ok guys, I got my cam spec by GPI but if I go ported heads I have to wait a long time as they have no cores at this time and I don't want the car down 4-6 weeks if I send them my heads.
What aftermarket cylinder head options would be good for my small speced vvt cam like mine?
Trick flow, AFR, darts? I assume I want the highest flowing smallest rectangular port ls3 head as I won't have a huge cam and bigger ports are not necessary and not great for low and mid range torque. When I was young AFRs always had the best flow numbers with modest port size but I am out of the loop with the LS3 type heads. I am being realistic and assume 20hp with an aftermarket head would be about it with such a small cam..... what are my options.
Thanks
ss camaro-monte is offline   Reply With Quote
Old 09-22-2022, 05:14 AM   #2
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
All will fo fine from the top manufacturers. I went PRC.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 09-22-2022, 10:06 PM   #3
ss camaro-monte
RHS seems to be the more budget based heads, PRC is mid range and then AFR are slightly more. From the flow numbers I can find it looks like MAST,AFR and Trick flow are top flow numbers but the trick flows do it will a 255 intake runner. I know from experience that the smallest runner that flows the most is usually best on a street car but I have had AFR heads before and have great faith in them. I will buy the cam set up first I think in the coming weeks.
Old 09-24-2022, 08:27 PM   #4
ss camaro-monte
Anyone use these as cast cnc chamber PRC heads? These are a pretty good price for the flow numbers. I am thinking these or go all out with the AFR Mongoose but I don't know if my mild cam will really benefit with a high end head like an AFR over these.
https://www.texas-speed.com/p-7650-p...der-heads.aspx
Old 09-24-2022, 09:16 PM   #5
bottletalk
Drives: 15 Camaro 2SS M6
Frankenstein engine dynamics, do a search.....pretty popular here
bottletalk is offline   Reply With Quote
Old 09-25-2022, 09:36 AM   #6
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Got them on my car. Great heads
CamaroDreams76 is offline   Reply With Quote
Old 09-25-2022, 01:31 PM   #7
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
https://www.camaro5.com/forums/attac...1&d=1664130583
Frankenstein ported heads with stainless valves and their .660 dual spring set up
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 10-06-2022, 04:59 PM   #8
Vicster
1000hp is NEVER Enough!
Vicster's Avatar
Drives: 13' ZL1
Head flow comparison. It may help...
1,000hp IS NEVER ENOUGH!!!
Vicster is offline   Reply With Quote
Old 11-20-2022, 05:36 PM   #9
plemon61
Drives: g8gt
I'm planning on the PRC as cast heads for my G8. They have good flow numbers for a smaller intake port and decently priced.
plemon61 is offline   Reply With Quote
Old 11-25-2022, 05:36 PM   #10
ss camaro-monte
I ended up getting the GPI Ported ls3 heads
