03-13-2022, 12:01 PM | #29 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
03-13-2022, 12:07 PM | #30 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
what made you pick him? im from cbus and never heard of this guy. and whats the difference with all this porting? standard vs x vs anything else?
03-13-2022, 12:10 PM | #31 |
2016 NFG 1SS A8
03-13-2022, 02:22 PM | #32 | |
Drives: 2018 Camaro ZL1 Join Date: Nov 2021
As for the port work, the Kong x port is supposed to shine when spinning the blower faster versus their standard port work. I don’t know what other porters are offering? |
03-13-2022, 05:01 PM | #33 | |
'20 ZL1 1LE A10,
03-14-2022, 07:23 AM | #34 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Brian Turner tunes a lot of cars in the Central Ohio area so he gets mentioned a lot by area car enthusiasts. He dyno-tuned my 2013 ZL1. Is he one the best tuners out there? That can be debated.
03-14-2022, 12:01 PM | #35 | |
'20 ZL1 1LE A10,
09-14-2022, 02:54 AM | #36 |
Drives: Camaro gen 6 zl1 1le Join Date: Jun 2022
Any Update who tune this car it runs maybe little to rich on dyno ?? I think nothing wrong with 650 whp only on 93 Octane
09-14-2022, 08:26 AM | #37 |
I retuned it for him on E50...it was rich prior .78. I leaned it out to .83 and added some timing through most of the curve. Also tuned the trans and raised the shift points. He dropped back to a 2.5 pulley, and it still makes over 12 psi. MAT went from 150's down to 130's. Not sure if he put it back on the dyno or not since. But I will say the X port is pretty nice. Since it doesn't hit as hard down low, the fuel system will go further. Not to mention it pulls all the way to redline instead of tapering off up top like stock blowers are known to do.
2016 NFG 1SS A8
09-14-2022, 11:41 AM | #38 |
Your making great power for those mods and the ported blower helps generate less heat. Do you live in a warm climate? That 2.3 may hurt you with timing getting pulled if your mats get to high.
09-14-2022, 12:47 PM | #39 | |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
09-14-2022, 02:54 PM | #40 |
644 is about right. Stock is around 565. I don't believe these cars realize the traditional 15% loss. This drive train is too good
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 09-14-2022 at 04:11 PM. |
09-14-2022, 03:53 PM | #41 |
Drives: E92 BMW M3 Join Date: Oct 2012
This is a great thread for someone trying to wrap their head around modding a ZL1. So much more to it than my old LS3. When fueling is needed is still a bit of a mystery.
I wasn't even considering porting the blower until reading up in here.
J-Rod Built and Matt@FSP Tuned |
09-14-2022, 10:40 PM | #42 | |
it just hits with less boost is all. Starts around 8psi in the 3k rpm range and builds to 12psi on the 2.5 pulley by 6500rpm.
2016 NFG 1SS A8
Thread Tools | |
