12-09-2020, 05:42 AM | #1 |
Drives: Chevrolet Camaro Join Date: Aug 2020
Camaro Windows problem
Hello
I have big problem with my camaro 2018 SS, I have bought my car from USA but when it arrived to me, windows dont work, Anyone here know what can be reason? I can tell you that battery was discarged when the car arrived to me |
12-09-2020, 11:45 PM | #2 |
Thank you Al Oppenheiser!
1. Check to see if the car is in transport mode (will say so when ignition is key-on). Certain BCM functions are disabled.
To remove the car from transport mode, turn ON the four way flasher and place the driver’s foot on the brake AND on the clutch if it is a manual transmission. Press and hold the Start button for approximately 15 seconds. At this point the engine will START, but CONTINUE to hold the start button for approximately 15 seconds. Information will display on the center of the cluster that will indicate when transport mode has been turned OFF. Transport mode can be entered using the same procedure. 2. Check fuses. Each has its own, some are in the trunk. https://www.autogenius.info/chevrole...e-box-diagram/ |
01-03-2021, 03:30 AM | #3 |
Ok thanks for your help
