09-18-2020, 12:20 PM | #15 | |
Drives: 2017 2SS M6 Arctic Blue Join Date: Dec 2019
2nd, this car doesn't have massive amount of engine braking in comparison to the manual cars I've owned or driven previously, or at least what I expected. There will always be cars out there with more or less of something than my current car. I haven't driven everything out there, but that doesn't change my comparison of what I've driven up to this point.
Mod list: - AWE Touring Catback - BMR Springs - GM Dark Finish Taillights
09-18-2020, 12:30 PM | #16 | ||
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
The Camaro doesn't have it, though I suppose the 1~4 skip shift on the V8 M6 models could be just as annoying for some. Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
09-18-2020, 12:31 PM | #17 | |
Hot Camaro
I feel that there's quite a bit of braking from the engine in this car, but it's offset by weighing close to two full tons with a tank of gas and at least a driver on board. In the end, it's still a push/pull between the engine trying hard to slow down a heavy car. Like you, I've also owned other manuals that felt like the engine braking "did more", but the car in question was also 1,000 lbs lighter. |
09-18-2020, 12:35 PM | #18 | |
Hot Camaro
What I've found myself doing as an adaptation is allowing the 1-4 to try and guide me but instead reacting as soon as I feel it to either swing up into 3rd instead or purposefully pushing the shifter to the right at slow speeds to come back and drop into second instead of trying to go direct. |
09-18-2020, 12:52 PM | #19 | |
Drives: Fast if no one's looking Join Date: Aug 2019
Installing the CAGS eliminator is the best $15 I ever spent in my entire life. Seriously. |
09-18-2020, 01:15 PM | #20 | |
09-18-2020, 01:16 PM | #21 | |
Hot Camaro
09-18-2020, 01:37 PM | #22 | |
Drives: 23 ZL1 6speed Join Date: Aug 2020
I feel the Camaro has a fair amount of engine braking. As others have said, there is some heft to the car. I also ALWAYS drive in track mode (there are other modes?? lol), if that matters. |
09-18-2020, 02:32 PM | #23 |
Drives: 2018 Chevrolet Camaro 2LT Join Date: Mar 2019
Nothing wrong with engine braking. When you engine brake your kinetic energy goes into compressing air which produces heat which then gets absorbed by the water jacket. An engine can absorb and expel a tremendous amount of heat, far more than you can generate with engine braking.
I have noticed if you watch the fuel consumption that when you let off the gas it takes several seconds before it goes into fuel cutoff and you actually feel the deceleration begin. I wonder if it is just the ECU just assuming you are going to shift? I wonder if it goes into cutoff sooner if you brake at the same time. |
09-18-2020, 03:11 PM | #24 | |
Hot Camaro
09-18-2020, 09:24 PM | #25 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
I engine brake with my A8 in manual mode all the time. The engine sounds glorious when downshifting while slowing down. I'm careful not to downshift from above 2500-3000 RPM or below gear M2, though I'm sure the transmission could handle it just fine.
If you are not doing this, I can't imagine you're enjoying manual mode much!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! Last edited by PnCRedJwl2SS; 09-19-2020 at 04:57 PM. |
09-18-2020, 09:52 PM | #26 |
Drives: 2017 Camaro 2SS Join Date: May 2020
Thanks for all the comments. I understand the car is heavy and there is a fair amount of engine braking. I was talking about the delay between letting off the gas and when the braking begins. I have Borla Type S mufflers and is is very easy to hear when the car goes into compression. The delay is significantly less in track mode compared to sport or tour. I have the 6M and rev match mostly on my own since that is what I do in my BMW Z4M. Guess I'm comparing the 3200 pound 3.2L Z4 with the 3900 pound 6.2L Camaro. My uneducated mind was expecting the 6.2L engine to make up for the 700 pound weight difference.
No worries, just want to make sure there was nothing wrong with my car. We do have some significant hills here in Utah so coming down a hill in a lower gear definitely saves brake heating. I have warped brakes in a SUV before so am cautious about overheating the rotors. By the way, I have had really good results with SP Performance drilled and slotted rotors and metallic pads on my Mazda CX9 and now my Acura MDX. |
Thread Tools | |
