Old 08-31-2015, 11:00 AM   #15
Memphis43
Memphis43's Avatar
Drives: Chevy
Originally Posted by Sledgehammer70 View Post
Considering how heavy 4 corner 6 piston Brembo brakes were for Gen 5. Not shocking 4 piston ones save this much weight.
But we have seen an option for the six piston setup on the new Camaro ordering guide. Part of a heavy duty brake package.
The question is how much more money and weight do they add?
Memphis43 is offline   Reply With Quote
Old 08-31-2015, 11:08 AM   #16
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Nice find!
JusticePete is offline   Reply With Quote
Old 08-31-2015, 04:11 PM   #17
GMGP5X
GMGP5X's Avatar
Drives: 2011 2LT RS VR 2008 Silverado 2500
I think they where talking about the car being 198 lbs lighter not just the brakes. I though you where just messing with me the first time I read your reply.
2LT RS VR / ARK DTS Cat back exhaust / Roto-Fab CAI / RPI stealth mud guards /Defender works billet chrome door sills/ DIY painted engine cover, trunk corners, and brake rotors / RX catch can / Team LLT badges. Team LLT
GMGP5X is offline   Reply With Quote
Old 08-31-2015, 06:19 PM   #18
SSNYSTR
SSNYSTR's Avatar
Drives: Black 2011 Camaro 2SS
If I don't plan on autocrossing or tracking my 6th Gen(maybe we once or twice) there's no need to get the 6 piston then huh? And save me some weight and money? I only plan on taking it to the drag strip occasionally.
SSNYSTR is offline   Reply With Quote
Old 09-11-2015, 05:46 AM   #19
toehead93
Drives: 2014 2SS/1LE
Originally Posted by jaymsu View Post
It will be dealer install option on 6th Gen as well, so price will be pretty high like it was with 5th gen.
Are you sure about that? Everything I see shows it as an LPO option which are installed in the assembly line. Just like the NPP exhaust, recaro seats, etc on the gen5. LPO pricing a supposed to be released this week but I have t seen it so it will hopefully be soon. Gam has not released the performance catalog that usually come out later and brakes are available now.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 04-01-2019, 06:12 PM   #20
joe1005@msn.com
Drives: Camaro lt1
Camaro lt upgrade
Was wondering if the rear wheel spindles from an ss will fit the lt?
Reason is the Brembo caliper /parking brake incompatibility
Was thinking of switching out the spindle,hubs etc so that the ss parking brake would now be on the lt
Obviously there would be more to it but that would be the majority of the solution
Just would have to figure out the actuator or a manual cable pull
joe1005@msn.com is offline   Reply With Quote
Old 04-03-2019, 07:45 AM   #21
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
The bigger issue will be integrating the change electronically. You can't just throw a manual pull cable on it because the electric park brake is an integrated part of the brake controller. Simply unplugging the motors will cause faults, and leaving the motors hanging will cause faults the first time the park brake tries to apply.
To properly use the SS style of park brake, you'd need to modify your wiring harness to connect the center-mounted park brake motor to the brake control module and then flash the brake control module with the correct software/calibration so it not only runs without setting faults since only one motor is connected, but also has the correct calibrations to apply the right amount of cable tension to achieve the desired park brake torque since that's different between the cable-pull setup and the motors being on the calipers.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 04-22-2019, 02:54 PM   #22
Osbornsm
Drives: 2018 SS 1LE
Originally Posted by Alpha1BC View Post
To properly use the SS style of parking brake, you'd need to:
- modify your wiring harness to connect the center-mounted park brake motor to the brake control module
- then flash the brake control module with the correct software/calibration so it not only runs without setting faults since only one motor is connected, but also has the correct calibrations to apply the right amount of cable tension to achieve the desired park brake torque since that's different between the cable-pull setup and the motors being on the calipers.
Umm, what he said. I got nothin here
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
