06-19-2022, 01:07 PM | #15 |
Drives: 21 ZL1 Join Date: Feb 2022
Here is my stock log showing my car warmed up idling fine with the LTFTs -12% to -13% but the short term fuel trims are perfect almost at zero. This means the car is completely happy and running correctly. At least in closed loop.
And the second photo is the log from my car with nothing but the rotofab added. No tune change or anything, still all completely stock same gas and everything. Here you can see the LTFTs are better. Closer to zero. More air going in means more fuel is needed and not as much pulled out from the factory airbox restriction. So the fuel trims are doing their job, and the shorties are still happy at zero-ish. |
06-19-2022, 04:50 PM | #16 |
Drives: Not yet…. Join Date: Apr 2022
Long term trims at 10% isn’t anything to be concerned about. Also, these aren’t 1988 TPI small blocks, or worse. They are not going to hurt themselves from a little romp down the road and back to clean the plugs. It’s a known deal with these. Run them like they were intended to be run and there won’t be any issues like this.
06-21-2022, 03:37 PM | #17 | |
06-21-2022, 04:07 PM | #18 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
And if we are talking specifically about the Camaro6, these are straight from the service manual. The 3rd column from the left indicates the "expected value". Now realistically, I don't believe anyone's LTFT will sit right at 0%, but anything within 10% either way is generally fine if you look at most cars' service manuals. It could be that OP's car just needs to be run hard, but again, I would just double-check everything else before trying the Italian Tune-up. Usually, small leaks or restrictions will only show up at idle due to the low volume of air flow at idle.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
06-21-2022, 08:26 PM | #19 | |
06-21-2022, 10:32 PM | #20 |
Thank you Al Oppenheiser!
The good ol' Italian tune-up ... yes it's still a thing.
Though I'd be looking for an air leak of I was running +10% trims consistently |
06-22-2022, 07:35 AM | #21 |
06-22-2022, 07:59 AM | #22 |
A/C on and the load % changes the trims
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) Last edited by 6spdhyperblue; 06-22-2022 at 04:01 PM. |
